'83 GSL oil leakage
Old Jun 16, 2002 | 02:22 PM
cpt_gloval's Avatar
KARATE EXPLOSION
'83 GSL oil leakage
my fb seems to be leaking oil a bit more lately (it's had a small leak since i've owned it). what should i look out for and where should i begin looking? donnie hayes said to worry about my OMP if it got much worse. so now i'm worrying
-brad
Old Jun 16, 2002 | 02:26 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
While the engine is running look in the down the carb, you will see the two brass fittings going into each primary you should see a small drop of oil come outta the tube. Also if you pull the lines at the carb it will drip oil on you.
Just go to Autozone and get some 2 cycle oil and start premixing the tank...I use Exxon TCW3 certified (low ash) red bottle $1.50 or so a bottle I forget... Dont sweat the OMP, just find the oil leaks
The1Sun
Mar 18, 2018 11:08 PM
