Did Mazda do this on purpose
Old Feb 13, 2010 | 08:34 PM
Chuck Norris FB's Avatar
Question Did Mazda do this on purpose
Have you guys notice that the renesis 13b rotor housings have this indentation on what use to be the exhaust port. Like if this was intentional by mazda since older 13b housings are becoming more scarce,This indentation plus some machining and machining a sleeve could enable the peripheral exhaust port..
What you guy's think??
Old Feb 14, 2010 | 09:44 AM
ArmyOfOne's Avatar
Bridge Port Freak
I think the problem would be cooling the sleeve. It would have to be some type of threaded insert because if the temperatures involved would make any epoxy or adhesive fail in that area.
Old Feb 14, 2010 | 11:06 AM
peejay's Avatar
Old [Sch|F]ool
It wasn't "intentional" but it was for a reason. They used as much of the old tooling as possible.
I don't know about the RX-8 engine or the FD, but even a series 5 FC rear end housing has the boss machined and tapped for a top-mount starter that they haven't used since, what, 1973?
All Series 3 engines have a boss for a turbo oil return in the front cover, too.
Sandro
3rd Gen General Discussion
24
Dec 30, 2017 03:35 PM
