question on injector pulse
Old Feb 12, 2010 | 01:22 PM
toddrs93's Avatar
Car does not start, I am sure I have multiple problems and I am just trying to narrow them down. The primary injectors show pulse for 3-5 seconds when cranking and then stop. If I stop cranking and start again the same thing happens, 3-5 seconds of pulse then nothing.
What could be causing this? I have went through the harness and checked grounds as well, that all seems to be fine.
Old Feb 12, 2010 | 03:22 PM
arghx's Avatar
rotorhead
is everything crank angle sensor related ok?
Old Feb 12, 2010 | 09:25 PM
toddrs93's Avatar
Its plugged in but I have not checked it any further. There is definitely plenty of fuel pressure and the pump is OK, I also discovered there is no spark.
I believe if the CAS were bad I would not have any injector pulse at all.
I seen another thread where the same thing was happening but there was no resolution posted. There's got to be something specific making it act this way.
Old Feb 16, 2010 | 04:47 PM
toddrs93's Avatar
still no resolution here
Old Feb 23, 2010 | 10:33 AM
toddrs93's Avatar
no ones ever heard of this before?
Old Oct 29, 2015 | 05:56 AM
twan's Avatar
did you ever find out what your issue was????? Im having the same problem. Thinking its the theft deterrent somehow but it doubt it. im getting spark but im gonna check to see if that doing the same thing.
Skeese
65
Mar 28, 2017 03:30 PM
elfking
Aug 19, 2015 09:48 PM
morataya
Microtech
Aug 16, 2015 09:39 AM
