fd water leak ?
Old Feb 11, 2010 | 11:52 PM
TypeR's Avatar
BC fd water leak ?
i recently took out my rear seats cause they kept getting wet
i dried up the part where the seats used to be and drove the car around for a bit an saw that it got flooded again i think thiers water in the frame or somthing
any help with how to get the water out would be great thnx
Old Feb 12, 2010 | 08:55 AM
mar3's Avatar
Administrator
Which car? The '92 or the '93...?
Old Feb 12, 2010 | 01:36 PM
TypeR's Avatar
1992 fd3s
Old Feb 13, 2010 | 12:47 PM
mar3's Avatar
Administrator
Well, any 3rdgen guru's have any ideas? If this was a 1stgen RX-7 or Firebird, I'd know exactly where that water was coming from but not an FD with no moonroof or rear window water channel trim prone to trapping water..
Old Feb 14, 2010 | 07:42 AM
dgeesaman's Avatar
Check for leaks in the spoiler holes or hatch glass.
Dave
Old Feb 16, 2010 | 04:50 AM
cyman's Avatar
window seal and also the rear wiper hole. the seals go bad and it can get in there.
is there water in the front footwells or only in the back?
Old Jul 26, 2012 | 01:45 PM
mstirts's Avatar
You may check the weeping holes for the back hatch, mine were clogged and causing the same issue.
Old Jul 26, 2012 | 04:10 PM
Sgtblue's Avatar
Urban Combat Vet
One or more of the spoiler mounts leaking? Otherwise pull your window trim and check the glass seal.
Old Aug 4, 2012 | 11:21 PM
jayjay's Avatar
any luck finding where it leaked
connerfd3s
Sep 19, 2015 05:58 PM
msilvia
15
Sep 11, 2015 12:13 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
gabescanlon
Sep 5, 2015 12:04 AM
