West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
Lug Nuts Question
Old Feb 10, 2010 | 11:40 AM
Marck's Avatar
Exclamation Lug Nuts Question
Well im planning on getting a little bit more offset for my fc (currently using 5mm, trying to go 10mm back and 8mm front)and i was wondering what lug nuts are used for bigger spacers? i need one that goes on a lot more threads than the stock one. Any suggestions?
Old Feb 10, 2010 | 12:19 PM
caredden's Avatar
Super Moderator
Veteran: Marine Corp
Sounds like you want longer studs.
A quick search in the "suspension" forum...
https://www.rx7club.com/showthread.p...t=longer+studs
Old Feb 10, 2010 | 12:30 PM
Renton's Avatar
Anything over 5mm is going to require longer studs or bolt-on spacers. What size/ offest are your wheels now? Also tire sizes. You may want to just go 10mm/ 15mm
Old Feb 10, 2010 | 03:48 PM
Marck's Avatar
my wheels are 205/60/r15 yokohomas i was just wondering if there was any lugs that screw in more when i have my 8mm wheel spacer rather than the stock one
Old Feb 10, 2010 | 04:23 PM
Renton's Avatar
Lug nuts that thread past your wheel? Yeah, I've got a set next to my flux capacitor and my time machine.
Old Feb 10, 2010 | 04:52 PM
Andrew.'s Avatar
The end of an era
You need longer studs or a studded spacer if you're going to go any thicker. If you try to put a thicker spacer, you're not going to catch enough threads with your lug nut and eventually, they'll back off/fall off/etc.
Old Feb 10, 2010 | 07:45 PM
frijolee's Avatar
the implications matter
Those are tire specs not wheel specs. Plan on $60 for studs (ARP for f-body camaro work well) and another $100 or so for spacers. Might but cheaper to just upgrade to a mustang wheel or something that fits how you want from the start.
Old Feb 10, 2010 | 11:40 PM
Spirit Rx-7's Avatar
rotard
i agree with the mustang wheels, i have some for sale for cheap if you plan to pick them up from socal
https://www.rx7club.com/west-sale-wanted-classifieds-195/fs-17x8-mustang-wheels-854807/
Old Feb 10, 2010 | 11:47 PM
Battle Cat's Avatar
Space cadet
just get better wheel with better offsets.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
