Is the Knight sport ecu chip in stock ecu good?
Old Jun 15, 2002 | 11:24 PM
I am purchasing a knight sport ecu chip for the stock ecu. Are these chips any good? the guy told me that its good for 14 pounds of boost
Old Jun 16, 2002 | 04:36 AM
anyone?
Old Jun 16, 2002 | 05:11 AM
My Advice
i have i only seen the knight sport mentioned a couple of times, since ive been around. but since your considering a chip, i would suggest looking into the pettit chip upgrade. from what ive READ ON THE FORUM about the pettit unlimited upgrade. pettit stats that it is safe up to 14.7psi. which is about the most you should run safely. try the search in the ecu section. just a suggestion.
Old Jun 16, 2002 | 07:09 AM
laujesse's Avatar
Thrashing your Roy score!
Veteran: Air Force
Are you getting the chip installed by that someone or are they just handing you the chip and saying have at it?
If you are just getting the "Chip" you also need the doughter board and you need to soldier in that doughter board...
Old Jun 16, 2002 | 07:12 AM
laujesse's Avatar
Veteran: Air Force
Knight sports has a wide variety of programs... for stock turbines at this boost and that... and single turbines at this bosst and that... Do you know exactly what you are getting? Knight sports is a very reputable company in Japan but you need to be clear on the specifics. Jesse
Old Jun 16, 2002 | 11:20 AM
dclin's Avatar
Perpetual Project
Exactly what Jesse says - have to consider that a rechipped ecu is as good as how close it is 'tuned' for your mods.
armans
Aug 15, 2015 09:08 PM
