Main Cat Air Tube
Old Feb 2, 2010 | 02:02 PM
zachariah2112's Avatar
Newbie
Main Cat Air Tube
I am trying to get my 88 t2 to pass emissions. The air pump and secondary air injection system are working and I changed my spark plugs and air filter. I just replaced my main cat and noticed that there is no air tube running to the cat at all. I am positive that this tube must run from the air pump somehow, but do know where it runs from. Can anyone let me know where this tube originates? Also, can I possibly pass emissions without the tube, as I hear the air pump only helps the cat at low rpms? Any help is greatly appreciated.
Old Feb 2, 2010 | 05:31 PM
Kentetsu's Avatar
Based on my knowledge of 1st gen systems, I would guess that you will pass emissions but your cat will soon burn up without that air tube being hooked up.
But wait for a 2nd gen expert to speak to this before making any decisions. Good luck...
Old Feb 2, 2010 | 05:35 PM
RotaryRocket88's Avatar
Top Down, Boost Up
95% of air pump air is fed to the exhaust ports, while only a tiny bit ever goes down the split air pipe to the cat. I'd bet that you could pass a sniffer test with the pipe missing, but not the visual. The pipe normally hooks up to an opening on the lower intake manifold, next to the turbo coolant feed line.
ZacMan
Sep 19, 2015 09:20 PM
NotMrButts
23
Sep 15, 2015 09:46 PM
