Sponsored by: CARiD
12a Trailing ignition help
Old Feb 2, 2010 | 07:16 AM
ducktape's Avatar
Fast-Trash
Exclamation 12a Trailing ignition help
I'm trying to build a trailing ignition from scratch with only a page or two from the FSM. I need a sanity check from someone who knows how this is wired. Motor is a stockish 12a with the OEM dizzy. I've wired up the leading through an MSD 6AL, so my only concern is the trailing at this point
Here's my current non-working config:
Key-on (+) to "B" terminal on the ignitor, split from there to the (+) on the trailing coil, split again (+) to the condenser.
Ground wire (-) from ground to "C" terminal on the ignitor, split to (-) on the coil.
So far all it has done is pop the key-on fuse when I give it power.
It all seemed sane according to the FSM. Here's the diagram I used to build this config. The circuit I was emulating is outlined in pink.
Can anyone point me in the right direction?
Old Feb 2, 2010 | 10:11 AM
ducktape's Avatar
Fast-Trash
The only thing I can think is that maybe the (-) should not be grounded directly, or that the condenser should be on the ground circuit.
Thoughts?
Old Feb 9, 2010 | 01:18 AM
installer67's Avatar
Dreamin of drivin my 7!
key on "+" to trailing coil "+", "B" on trailing igniter to "+" on trailing coil, coil "+" to condenser, "C" from trailing igniter to "-" on trailing coil. Don't directly ground the coil or igniter. Dizzy housing is ground for the igniter and shares with the coil.
Old Feb 12, 2010 | 06:07 PM
ducktape's Avatar
Fast-Trash
Thanks for confirming that for me. It took a bunch of fuses to figure out that ground was superfluous.
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
ncds_fc
19
Sep 15, 2015 12:03 AM
heywier427
Naturally Aspirated Performance Forum
Sep 11, 2015 04:49 PM
