I never knew
Old Jan 29, 2010 | 02:35 PM
Deblin's Avatar
JDM as fuuuuuu
I never knew
that when you took off the intake, all of the coolant would come spilling out, although it kind of makes sense. Here's to hoping I can get it cleaned up before the neighborhood cats ingest it and/or the EPA makes a random drive by and throws me in jail.
Old Jan 29, 2010 | 02:45 PM
PercentSevenC's Avatar
I need a new user title
Freeze plugs FTW.
Old Jan 29, 2010 | 04:12 PM
Deblin's Avatar
JDM as fuuuuuu
How big? What's the point of that coolant passage anyway? The only thing I can think of is that it's to help shed heat from the coolant even more, but I'm not entirely sure.
Old Jan 29, 2010 | 04:38 PM
rxtasy3's Avatar
the stock intake has this passage thru it for cooling.
Old Jan 29, 2010 | 04:48 PM
j_tso's Avatar
I thought it was to help the carb warm up.
Old Jan 29, 2010 | 06:36 PM
Deblin's Avatar
JDM as fuuuuuu
For cooling the coolant, you mean? Cuz it's certainly not going to cool the intake charge, even here where it's 95 every day of the summer.
Old Jan 29, 2010 | 06:52 PM
Sgt Fox's Avatar
Stigulus Moderatorai
Coolant runs through the intake manifold to get the engine up to temperature faster/ prevents carb icing. This helps both cold startups as well as reduces emissions as a cold engine produces more emissions.
Do you have a hose? If you dilute the area where the coolant spilled, you will reduce the risk of harm to a cat or whatnot.
Old Jan 30, 2010 | 04:14 PM
Deblin's Avatar
JDM as fuuuuuu
I cleaned up all the coolant, through copious amounts of paper towels and a hose. Hadn't thought it'd be to help cold startups though.
Old Feb 1, 2010 | 02:26 PM
Jeff20B's Avatar
Lapping = Fapping
The air control and check valve in the intake manifold is heated by exhaust. The coolant keeps the manifold from getting too hot. It's simple, really.
Old Feb 1, 2010 | 04:50 PM
Originally Posted by Deblin
How big?
Mazdatrix sells them in the correct size.
http://www.mazdatrix.com/b1.htm
Old Feb 1, 2010 | 05:24 PM
Sgt Fox's Avatar
Should be just a 20mm frost plug. No need to pay to have them shipped.
Old Feb 1, 2010 | 10:13 PM
Crit's Avatar
No distributor? No thanks
A pair of 20mm plugs from Autozone will take care of it. Lots of spec-race series require you plug them so that you can get your ports checked without pissing all over the paddock.
FWIW, a GSL-SE's fuel injector bungs take a 16.4mm plug (common on Geos for some reason). Racing Beat's bogus-injector kit is a total waste!
Jmolina0163
19
Sep 25, 2015 06:06 PM
Vartok
Sep 24, 2015 02:20 PM
turbodreamz22
Interior / Exterior / Audio
Sep 21, 2015 06:20 PM
SCinfidel
Sep 8, 2015 05:36 PM
