best way to lube the rotary?
Old Jan 25, 2010 | 01:41 AM
gonzofann's Avatar
CA best way to lube the rotary?
Hi in confused, I read on youtube if the rotor gets enough oil it can last 200,000. miles before rebuild.
how due you lube it? is there a remote pump that only sparys in enough oil for each rpm, or do you just pour in some two stroke oil after you fill it up at the gas station?
Thanks Joe
Old Jan 25, 2010 | 08:46 AM
Pele's Avatar
Right near Malloy
The Metering Oil Pump (MOP or OMP as people like to call it) is located on the front cover of the engine, towards the right hand side of the engine. (Near the exhaust manifold.)
It will inject oil into the engine to lubricate the seals.
Sometimes people take it out or it fails. A little 2 stroke in the tank won't hurt. People call this Premixing.
They usually use a 128:1 ratio of Fuel to Oil.
On 1988 and earlier engines, it is mechanical. The engine spins it and it is controlled by the throttle.
On 1989 and later vehicles, it is electronic and controlled by the ECU.
It is connected to the intake and/or oil injectors on the housing by plastic tubes.
Old Jan 25, 2010 | 01:00 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Thanks Joe
I wouldn't be using youtube comments as a source of reliable information.
I prefer to keep the OMP functional, so I don't have to mess around with premixing at every fill-up. But that's mainly due to the fact that I have an S4 mechanical pump, and not the failure-prone S5 pump.
Old Jan 26, 2010 | 01:53 AM
gonzofann's Avatar
thank you
Old Jan 30, 2010 | 07:58 AM
viper1_2001's Avatar
My other car has 2 wheels
Even if you have a working omp it still is a good idea to pre-mix alittle when you remember about it, you never know if it might quit working one day
Old Feb 1, 2010 | 11:22 PM
chobotRX7's Avatar
ROAD RACING RULES
i mix my 12a 4-5 oz to 5gal of fuel it works . i get litle smoke here and there but nothing major and only in hi rpm 6800-7500 . it is a 12a stock port with r b headers 2.5 inch straith exhaust magnaflow mufler and a 48 weber with 185 jets air and fuel and msd ignition with the fuel ragulator set at 4 psi dont know how many hp but i thing somwhere 140-160 not sure. motor is runnig perfect no deadspots at all hope the info was usefull
datfast1
Old School and Other Rotary
18
Jun 20, 2019 10:53 PM
Under PSI
19
Sep 23, 2015 11:47 PM
datfast1
West RX-7 Forum
Sep 14, 2015 06:58 PM
andyvideopro
SE RX-7 Forum
Sep 5, 2015 06:56 PM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
