AVC-R Sensor Sel ?
Old Jan 24, 2010 | 11:26 AM
Carpenter's Avatar
T67, did I say 7?
AVC-R Sensor Sel ?
Can users of the AVC-R, explain the following.
In the etc screen, in Sensor Sel-
1. Relative1 Relative Boost Pressure Sensor
(Normal Range)
2. Relative2 Do not use
3. Absolute1 Do not use
4. Absolute2 Do not use
*Select [1. Relative1] when using the included Pressure Sensor
What is the differences between all four? Please be specific.
The manual does'nt go into detail.
Old Jan 31, 2010 | 12:02 PM
rain_mk14's Avatar
I could not explain exactly, but I think they are different way to calculate the values of the pressure sensor. I was comparing the boost values with Relative1 option and the values the Power fc with the apex 3bar map sensor and it was 3psi off, so I played with it a little bit and left it on Absolute2 because it was the closest one.
I know its not what you where asking, but its my experience with this device.
Regards...
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
rotor_veux
Sep 19, 2015 07:13 PM
