Wastegate issues.
Old Jan 24, 2010 | 12:24 AM
FDrifting7's Avatar
Wastegate issues.
I have a 44mm tial wastegate, and I cant get it to hold spring pressure.
I have the pressure source coming straight out of the compressor housing, directly to the side port of the WG. The top port i just left open.
The boost isnt even near spring pressure... it skyrockets up into 17-20 area. I checked my spring and it's the green 11lb one.
The WG is brand new from a-spec. Could it be stuck? Could the diaphram be bad?
I can't come up with any conclusions. Suggestions would be nice. thanks
Old Jan 24, 2010 | 12:52 AM
7passu's Avatar
supra7
You can use a air blower hooked to that vacume line running to the gate to see if it opens under pressure. Turn it down to like 50 psi if you can ans just bump the blower a lil and see/listen for air leaks or to hear if it clicks open or not....
Old Jan 24, 2010 | 04:34 AM
NoPistons!'s Avatar
Tango Down
Take the wastegate apart and put some high temp anti seize on the valve shaft and see if that makes a difference. It could very well be sticking.
Definately pressure test it OFF the car. It should open at 11 psi if you have an 11psi spring.
The only other thing i can think of is poor wastegate routing on your manifold causing it to creep up like that OR the spring is marked incorrectly which is unlikely but should be looked into regardless.
Old Jan 24, 2010 | 10:00 AM
rxspeed7's Avatar
F-IT
yeah sucker i told you to come over yesterday so we could get it off and look at it
Old Jan 24, 2010 | 10:25 AM
zeaone's Avatar
I would hook up vac from upper intake after tb
Old Jan 24, 2010 | 11:12 AM
BigTurbo74's Avatar
That will make it worse. It is best to come straight off the compressor housing.
What is your turbo setup? If you have a heavily ported engine and a big turbo the w/g must be placed correctly. Its just happening in the higher rpms right?
Old Jan 24, 2010 | 04:39 PM
rxspeed7's Avatar
F-IT
its basically a 500r setup with the short runner a spec manifold. the source is right from the comp housing as it should be. its a stock port rew motor with the a spec kit on it. when we get it off we'll let you know the findings.i believe its just jammed, so when we get it apart im going to lube the valve with antiseize and make sure theres no obvious issues
Old Jan 24, 2010 | 04:57 PM
rx72c's Avatar
Top Answer: 1
Is the manifold designed with such a small gate in mind?
Old Jan 24, 2010 | 05:30 PM
FDrifting7's Avatar
i bought it from a spec and I'm guessing the 44mm wg should be big enough for my setup. Its overboosting as soon as the turbo can make boost from like 3500-4000 and up.
Zack, we need to get a pressure tester and hook it up. Ill be over asap though.
Could a brand new wg just stick if it sat around for a while?
Old Jan 24, 2010 | 08:34 PM
rxspeed7's Avatar
F-IT
yep but the only way to tell if it opens with that is to take it off. it should only take like 20 mins to do
Old Jan 24, 2010 | 09:07 PM
psiturbo's Avatar
MazdaPowered
FL
Use like a bike pump and connect it to the line to see if it opens up. It could be defective.
Old Jan 24, 2010 | 09:13 PM
rxspeed7's Avatar
F-IT
thats the plan
Old Jan 25, 2010 | 05:37 PM
FDrifting7's Avatar
okay... so I took the WG off and pressure tested it with an air tank.
the valve SLIGHTLY opens at 17 psi.
and when i put it down to 15psi, it didnt move at all. But i could hear some air seeping around where the piston shaft goes into the upper part of the WG. Is that normal?
So I'm guessing I need a new spring. Although the spring is green and should be .8 bar, or around 11 psi.
Maybe if i go with a 5lb spring i can actually hold steady boost pressure. Where can i get a tial 44mm 5lb spring for a decent price?
Has anyone ran into this before?
Old Jan 25, 2010 | 06:11 PM
FDrifting7's Avatar
I just ordered the small red spring that should open at 4.35 psi.
I got it second day air shipped... so i will let you know what happens when it get here!
Old Jan 25, 2010 | 09:16 PM
Carpenter's Avatar
T67, did I say 7?
At what point (PSI), did it open up? 18?
Old Jan 26, 2010 | 01:43 PM
FDrifting7's Avatar
yes. It started to slightly open around 17. and when I gave it 20 it open decently quick. but i want it to slightly open at 10! lol
Old Jan 27, 2010 | 05:11 PM
PandazRx-7's Avatar
Fast + Reliable = $$$$$
If I'm not mistaken, you need pressure both on the diaphragm and the valve (exhaust) to open correctly. I also had creep issues with my long runner 500R kit...ended up going down to a 10psi spring to hold minimum 13psi.
Pressure tested the Tial and was told the slight leak around the shaft is normal and would be minimal after expanding from the heat. Let us know what happens.
Old Jan 27, 2010 | 05:21 PM
DriftDreamzSS's Avatar
ive seen the same problems with a tial v44. Im now running a 7psi spring to hold 10-11 psi on a 35r/hks tubular manifold with a high flow cat, straight pipe its worse.
Old Jan 27, 2010 | 05:35 PM
moehler's Avatar
As long as the air is coming out the inside of that shaft (around the valve stem) then it's normal. If the air is coming out from outside the shaft (where the spring housing meets the WG body) then its not normal. Mine did that - turned out to be a bad O-ring under the nut that holds the body to the housing. I bought a replacement from McCaster Carr. I also used a copper silicon sealent just to make sure it wasn't ever going to leak again. If you remove the nut make sure to use a high temp threadlock sealent.
Old Jan 27, 2010 | 11:21 PM
FDrifting7's Avatar
Yah it just slightly leaked around the valve shaft.
Old Jan 28, 2010 | 11:19 AM
WaachBack's Avatar
Finally Knows
Same here, I have a 13lb spring and it holds about 16-17psi.
Old Feb 1, 2010 | 06:51 PM
FDrifting7's Avatar
okay so i installed the 5 lb spring today, and the car now holds around 8lbs steady.
I finally have controllable boost!
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
FC3S Timmy
16
Oct 3, 2015 01:08 AM
Devon Murray
Sep 26, 2015 08:15 AM
