West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
anyone in the SF bay area
Old Jan 23, 2010 | 01:26 AM
magus2222's Avatar
On the fasttrack!
im looking for someone in the SF bay area that is throwing away a front subframe for an FD. i dont care if its fucked up or not, i need it for my 13brew conversion in my fc.
anyone have any better ideas for mounting the 13brew? i figured i could take the stock mounts and weld them into my subframe.
anyone else doing this in the yay?
Lloyd
Old Jan 23, 2010 | 01:55 AM
smog-guy707's Avatar
Wangan Junkie
Airquin up in sac was also looking into this swap... ???
Old Jan 23, 2010 | 11:27 AM
airquin23's Avatar
Team U.R.S
ya i was...not no more. A lot of extra work and don't want my car down for that long. there was someone in i believe yuba? that made a brace for the bottom that used the stock fc motor mounts. I got the name from SmogSux he knows who they are. Good luck with the build though.
Old Jan 23, 2010 | 10:58 PM
3rd and final 7's Avatar
wheres the water goin?
i dont know how much your looking to spend but couldnt you use theses http://banzai-racing.com/store/13B-R..._brackets.html
Old Jan 24, 2010 | 08:13 PM
magus2222's Avatar
On the fasttrack!
nope, they are bre, the brew mounts differently, already read banzai specifying that.
i could love to just chop an original fd subframe, but if i have to come up with something, so be it.
Lloyd
Old Jan 24, 2010 | 10:08 PM
airquin23's Avatar
Team U.R.S
Hit up smogsux that place that he told me about made it and they were not very expensive.
Old Jan 24, 2010 | 10:15 PM
Funkspectrum's Avatar
I'll most likely be doing the same swap into my FC eventually. Instead of using the aftermarket methods of dropping the engine in, I'll probably just tap the center iron and use an FC oil pan so it becomes a drop in affair...
Old Jan 24, 2010 | 10:39 PM
magus2222's Avatar
On the fasttrack!
ya, but i dont want to do that, ide rather be unique and make a mount and make it look factory without messing with the engine.
Lloyd
Old Jan 26, 2010 | 01:37 AM
AmviciousRav's Avatar
GTR
Originally Posted by funkspectrum
i'll most likely be doing the same swap into my fc eventually. Instead of using the aftermarket methods of dropping the engine in, i'll probably just tap the center iron and use an fc oil pan so it becomes a drop in affair... :d
+1 I'm pretty sure someone you know would say that as well
Old Jan 29, 2010 | 12:16 AM
magus2222's Avatar
On the fasttrack!
anyone else?
Lloyd
Old Jan 29, 2010 | 12:17 AM
Wangan Junkie
im sure if you post up a WTB thread in the classifieds you will get something
Old Mar 7, 2010 | 02:06 PM
Hey Lloyd saw these and thought of u at the bottom of page are these what you looking for http://www.shookmotorsports.com/FCProducts
scissorhands
Sep 16, 2015 01:25 PM
Tem120
Sep 7, 2015 09:53 AM
