aftermarket gauges and wiring in 1989 rx7
Old Jan 20, 2010 | 09:29 PM
dusterbd13's Avatar
NC aftermarket gauges and wiring in 1989 rx7
im working on an 89 rx7. the thing is really well worn, but makes for the perfect start for a bare bones race car.
the first order of buisness is to get the electrical sorted out. the car had no wiring to speak of. bery hacked, incomplete, etc. i have all the switches for the lights, heater, sunroof, and horn. that is all i plan of retaining at the moment. that will all be strung together with an 18 circuit painless harness.
the istrument cluster is what im working with now. oil pressure, water temp, volts, tach, speedo, and fuel level gauges are all that i will be running. indicators for the turn, high beam, and a warning light for the nitrous being armed.
to that end, i cant seem to figure out what fuel level gauge i need. the manual says that the sender is a 6 ohms full, and 110 empty. i can find gauges, but none that seem to run backwards. what are you guys using?
also, anyone have a simplified pinout of the factory switches im going to be retaining? such as power, ground, function, etc?
thanks for any help for a japanese car newbie.
michael
Old Jan 21, 2010 | 10:56 PM
farberio's Avatar
NASA-MW ST4
Your best bet is going to be finding a FSM and pouring over the wiring diagrams.
You can find one by typing in RX7 FSM into google.
Old Jan 22, 2010 | 12:54 AM
Prozium's Avatar
I failed the turing test
this link is in the first gen section but the link has the FSM, wiring diagrams, and parts manual up for free. If all else fails, go to a Mazda dealer and see if they can order you a fuel level gauge. GL with the build
https://www.rx7club.com/1st-generation-specific-1979-1985-18/download-copy-your-year-fsm-click-thread-get-link-874699/
Old Jan 22, 2010 | 06:42 AM
dusterbd13's Avatar
guess i should have been clearer that im running autometer gauges.
i also have the wiring diagrams, they are just really confusing to me right now for some reason. i just cant seem to make out what the colors are based on th ediagram. and then i cant sem to translate that to whats left of my wiring harnes.
thanks for the replies, guys.
michael
LMBTG
Aug 15, 2015 01:43 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
