BNR stage 1 question.
Old Jan 20, 2010 | 12:12 AM
ZenkiFCdrifto's Avatar
CA BNR stage 1 question.
I was thinking about getting a stage 1 BNR upgrade but my s4 is mostly stock, full 2 1/2 inch straight exh,hks power suction intake(pretty much a mushroom shaped filter), emissions removed,blitz bov,and a old school hks FCD(not installed) how bad or if any the consequences of going to a stage 1 Turbo will be? any help would be greatly apprecited.
Old Jan 20, 2010 | 12:35 PM
RotaryRocket88's Avatar
Top Down, Boost Up
A hybrid turbo on stock fuel is a bad idea. Stock boost levels should be fine, but any more than that will blow the engine.
Old Jan 20, 2010 | 04:49 PM
Go48's Avatar
Talk to Brian at BNR for suggestions on fuel/ECU upgrades to run with the Stage 1.
Old Jan 20, 2010 | 07:13 PM
CA cool
Thanks alot ill give him a call.
Old Jan 20, 2010 | 07:16 PM
CA wait.....
what is the possible max output on a stock turbo with supporting fuel mods?
Old Jan 20, 2010 | 08:03 PM
soulrider's Avatar
im pretty sure that over 12 psi would blow your engine
Old Jan 21, 2010 | 05:23 AM
Go48's Avatar
Maybe the following will give you a useful datapoint.
My S5 Turbo with stock turbocharger (highly ported wastegate), HKS intake, RB REV-II turbo-back exhaust system, and FCD dynoed at 222 WHP/205 ft-lbs torque at 7 psi. No other engine mods.
I recently installed a BNR Stage 1 turbocharger (mildly ported wastegate), Supra TT fuel pump, RC 750cc secondary's and an Rtek 1.7 chipped ECU. These were the mods suggested by Brian. I'm hoping to dyno around 270-280 WHP at 10-12 psi boost with these mods.
LongDuck
Oct 7, 2015 08:12 PM
matty
40
Oct 6, 2015 09:13 PM
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
