need help BAC valve question
Old Jan 19, 2010 | 05:48 PM
rotor1991's Avatar
I was told my idle prob was probly from my BAC valve i have took it off and tested it i unpluged it from the car first and the idle didnt change at all. then i tested the resistance and it said it was supposed to be between 9-13 ohms it was at about 26. i tested it and it does click and there is 9 volts comming through the plugin. i was wondering if it was bad or it didnt have enogh volts.
Old Jan 23, 2010 | 10:42 AM
Aaron Cake's Avatar
Engine, Not Motor
Testing the BAC in this way is almost pointless.
A short pulse with 12V should cause the BAC to click and the plunger to move. Only apply it for a split second as to avoid burning out the oil. If the BAC works, then it probably just needs to be cleaned out. Use carb cleaner.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
Nosferatu
Sep 5, 2015 02:13 PM
