wheel and tire fitment enkei pf01's
Old Jan 15, 2010 | 02:36 AM
sgt fury's Avatar
one jelly doughnut
looking for a good size for my setup. i'm running a burnout widebody with coilovers and enkei pf01's. my size options are 18x9.5 with 15,35,or 45 offset or 18x10.5 with 15 or 45 offset. i want to run either 275's or 285's and i'd like the offsets to be the same for rotation purposes. any ideas?
Old Jan 15, 2010 | 09:11 AM
johgar's Avatar
Garage_Techno
I would try +35 front and +15 for the rear.
Old Jan 15, 2010 | 10:32 AM
Battle Cat's Avatar
Space cadet
i ran 17x9 +22 and 17x10 +18
if you want to be conservative, go for +25 front and +22 rear.
Old Jan 15, 2010 | 11:04 AM
ARD T2's Avatar
i have these wheels arriving late February or Early March in the high and low offsets.
For the Burnout Kit i'd suggest running the 10.5" +38 offset and then using spacers to get it exactly where you need.
The Burnout kit is only about 20mm wider front and rear I believe. If that's the case I would think a 18x10.5 +25 would be ideal to run with 285's or wider. Technically the 9.5" isn't wide enough for the 285/30/18.
So in order to get as close as possible to the ideal offset you will get the 10.5" +38 and then run a 15mm studded spacer.
My suggestion would be to get the wheels first, put the tires on them, install onto the car. Then take final measurements for the spacers so your front and rear are equally "flush" with your fender.
IF YOU WANT EM LET ME KNOW AND I'LL LOCK UP A SET WITH DEPOSIT.
Thanks,
Rishie
Old Jan 15, 2010 | 12:05 PM
sgt fury's Avatar
one jelly doughnut
thanks guys for all the info.probably go with the 10.5s and 285s in 38 offset
