Midwest RX-7 Forum Serving KY, IN, IL, MO, MI, WI, IA, MN, ND, SD, NE, KS
Help In NW Indiana!!
Old Jan 14, 2010 | 01:53 AM
FCRotativo's Avatar
I am in need of help with a 1989 turboII, it was practically gifted to me for $400, the car is spotless and it came with zeal coilovers. BUT... The engine bay is empty and I do not know where to start , if anyone can take a look and guide me I would be grateful. Lunch and beer included!
Old Jan 14, 2010 | 02:30 PM
silverbulletrt02's Avatar
Dreams bigger than wallet
contact Japan2LA on here and get a engine/trans from him.
why was the motor pulled? is the trans/diff/axles still there? i doubt its there, but engine harness? ECU?
Old Jan 14, 2010 | 03:22 PM
FCRotativo's Avatar
Yes, the tranny and differential are there, so is the ECU and engine harness. The engine harness is stripped of all insulation/protection and missing a few connectors though.
I received the engine disassembled, not sure what is missing. The engine was pulled because of the rear rotor blew due to fuel cut.
Here are my concerns:
1. What is missing from this disassembled engine and if its worth rebuilding? (housing conditions, plates, etc)
2. Tranny/axle/differential conditions
Basically need someone that knows their **** to assist me, becaue Im a noob to the Rotary world.
Old Jan 15, 2010 | 10:49 AM
Take some pictures of the housings and rotors and post them up here.
Old Jan 15, 2010 | 07:06 PM
rolfs_7's Avatar
i play with my wankel
what are you worried about with the trans and diffy? drain ur fluids and observe color and if anything falls out. Fine particals like dust/sludge is normal, if it falls out like chunky milk its a concern and if it clogs enough u gotta pull it apart and you find chunks that you can read part numbers off of then its F'ed up! Check your CV boots on ur axles for tears/cracks.
Do what silverbulltrt02 said and post some pics up.
Old Jan 17, 2010 | 11:37 AM
Railgun's Avatar
I won't let go
Veteran: Marine Corp
Shoot me a PM. If you're off tomorrow I may be able to come by to take a look. I'm just over in Schererville.
Lou Byer
20
Oct 12, 2020 08:03 PM
sdecours
Sep 15, 2015 08:50 PM
DrKillJoY
South RX-7 Forum
16
Jun 29, 2005 03:11 PM
rx-7girl
23
Mar 9, 2002 01:14 PM
