Power FC Possible ignition problem...
Old Jan 13, 2010 | 09:15 PM
dwb87's Avatar
This is my social media.
Exclamation Possible ignition problem...
It has been quite a while since I have started my RX-7. Probably 9 months or so. I tried to start it the other night and made sure I was getting fuel, but I'm not so sure that it was getting spark.
So, I figured... Maybe the PFC commander can give me some information. I'm not a tuner and am not totally sure if I was getting the right information, but when I looked at the commander for the leading ignition graph and trailing ignition graph, while starting the car, the graph lines did not change at all. Could this possibly mean that I am not getting spark? Could it be the plugs? It was about 29-32 degrees outside too...
Old Jan 14, 2010 | 10:16 AM
arghx's Avatar
rotorhead
Ignition timing is fixed during cranking. But I didn't see your screen so I can't be sure what's going on with your car.
What are the symptoms? It just turns over and won't fire? Did you check for spark at the coils yet?
Old Jan 14, 2010 | 05:15 PM
dwb87's Avatar
I haven't checked for spark at the coils. How do I do so??
Old Jan 15, 2010 | 09:23 PM
cewrx7r1's Avatar
Eye In The Sky
I suggest you go to your local libary and read some books on basic automotive systems and trouble shooting. Then study section F of the field service manual. This forum is not for beginners.
After that, go to the 3rd gen forum for such basic questions.
Old Jan 16, 2010 | 02:56 PM
dwb87's Avatar
Sometimes I am ashamed of being an RX-7 owner... Because of people like you. It sucks to know that no one here is like family. Thanks~
Old Jan 16, 2010 | 05:19 PM
prjct87rx7's Avatar
REST IN PEACE DAVE!!!!!!
i have to agree with you. lol
pull off your leading spark plug wire,put a screw driver into the end of your wire,then place it right next to your strut tower bolt.. make sure its not touching anything else and is within say half inch away and when you crank it over the spark will jump from the screw driver to the strut bolt confirming you have spark to the wires.
you probably need plugs
Old Jan 16, 2010 | 05:33 PM
dwb87's Avatar
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/checked-l-t-coil-resistance-problem-882719/
WANKfactor
Sep 29, 2015 01:14 PM
GKW
Sep 28, 2015 04:34 PM
subeone
Sep 24, 2015 09:58 PM
ncds_fc
19
Sep 15, 2015 12:03 AM
