clutch problems
Old Jan 11, 2010 | 06:02 PM
brap12a's Avatar
NJ clutch problems
i have a 85 mazda rx7 with the 12a,now my problem is when am driving i have to pump the clucth alot of time some i could get a pedal and so i could be able to go to gears or else the pedal goes down to the floor and the gears wont go in ...what could it be?
Old Jan 11, 2010 | 10:03 PM
mar3's Avatar
Administrator
Clutch hydraulics ~~ Replace the clutch master cylinder and the slave cylinder. If the rubber line has any signs of aging like deep cracks, replace it, too.
It's a lot easier and more time effective to replace it all than to try to rebuild all of it.
Mario III
Old Jan 11, 2010 | 10:08 PM
funkjaw's Avatar
Check for any visible leaks you may be able to get away with just replacing the slave cylinder or a line or something... although the above post is definitely good advice; it is always a good idea to replace everything with some brand new quality parts when you buy an old car such as a 1st gen Rx7.
Enzo1944
Sep 6, 2015 08:57 AM
vmerino
Sep 5, 2015 11:26 AM
