Centerbore of an FD?
Old Jan 2, 2010 | 01:40 PM
XxMerlinxX's Avatar
Team Benjos Captain
Hey guys, just a quick question. Is the centerbore of the FD 67.1mm? Thinking about getting some 5mm spacers upfront so my tires will quit rubbing and needed to know, that way the spacers I get will be hub centric.
Old Jan 2, 2010 | 01:58 PM
Mahjik's Avatar
Mr. Links
Yes the FD centerbore is 67.1.
Old Jan 2, 2010 | 03:30 PM
XxMerlinxX's Avatar
Team Benjos Captain
Thank you sir, I appreciate it.
Old Jan 2, 2010 | 04:18 PM
the tires are rubbing on the inside?
Old Jan 2, 2010 | 05:57 PM
XxMerlinxX's Avatar
Team Benjos Captain
Yeah, they are. My offsets are a little low and I need slightly taller tires to keep my lip off of the ground, so it scrubs every once in a while on full lock.
Old Jan 2, 2010 | 06:00 PM
Mahjik's Avatar
Mr. Links
I'm assuming you mean "offset too high". The lower the offset, the further "out" the wheel is from the center of the car. So using a space will make the offset even "lower". What is the size and offset of the wheels you have?
Old Jan 2, 2010 | 07:27 PM
XxMerlinxX's Avatar
Team Benjos Captain
Apparently I'm confused, because not only did I think a lower offset meant closer to the hub and that I had +38's, but I actually have +45's. My wheels are 17x8 and have 235/45/17's on them.
Old Jan 2, 2010 | 07:43 PM
Mahjik's Avatar
Mr. Links
Send a PM to Rishie:
https://www.rx7club.com/members/ard-t2-1620/
He can get you what you need and make sure what you get will definitely work for you car.
Old Jan 2, 2010 | 08:37 PM
XxMerlinxX's Avatar
Team Benjos Captain
I'm not real keen on Rishie at the moment. I posted a thread in his section asking if he could get Rays valve stems for me and he never replied. There are some hub centric 5mm spacers on ebay that I can pick up for $40, so I'll probably just go with those.
artowar
58
Jan 24, 2008 09:13 AM
wReX
Nov 15, 2003 07:53 PM
gate98
Jul 21, 2003 07:49 AM
rx7gslse
Mar 21, 2003 01:46 PM
newRX7fan
Aug 7, 2001 05:31 PM
