Sponsored by: CARiD
charge relief valve question
Old Dec 20, 2009 | 10:58 AM
iyad's Avatar
just went for a test drive and i was not hearing it open...so i went to take it off and the small hose on and it had pressure...is this normal?
Old Dec 20, 2009 | 04:07 PM
Mahjik's Avatar
Mr. Links
The charge relief valve is OPEN (off) until around 4000-4200 rpms when it CLOSES (on) under load. Check this chart:
http://www.autosportracetech.com/RX-...erOverview.htm
Old Jan 3, 2010 | 12:12 PM
iyad's Avatar
if i want to change the bov to an aftermarket one do i have to change both and what kind
Old Jan 3, 2010 | 02:24 PM
Mahjik's Avatar
Mr. Links
You only change the one closest to the airbox which should be labeled ABV.
Old Apr 14, 2010 | 09:12 PM
iyad's Avatar
i got a low vacuum pressure on my boost gauge and the car is not running proper on idle could u help me on that.
i got all new hoses installed
Old Apr 17, 2010 | 09:43 AM
Mahjik's Avatar
Mr. Links
What is your idle rpm and what is you vacuum reading at idle?
whinin
Mar 30, 2019 07:53 PM
SakeBomb Garage
Oct 9, 2015 10:05 PM
galvatron10000
Canadian Forum
Sep 8, 2015 08:50 PM
