Alarm install and power locks
Old Dec 18, 2009 | 12:33 AM
pinnach's Avatar
I tried doing a search on this but no dice. Here's the scenario: my fd had an ancient viper so I decided to upgrade to a newer 2 way viper. I've wired all the main components and it's all working fine. However, my passenger lock is not working at all. The driver door has an aftermarket actuator but the passenger door doesn't. Did I screw something up or do I need to add another actuator on the passenger door? Also, I wouldn't mind hooking up the remote start feature but the installation manual doesn't give me much info on it. Does anyone know if there is some kind of wiring diagram available? Any and all help will be appreciated.
Cheers,
Dan
Old Dec 18, 2009 | 02:55 PM
pinnach's Avatar
update: I just realized that my power window switch on the driver door also doesn't work. I'm starting to lose my mind with this!
Old Dec 18, 2009 | 03:20 PM
pakitagn's Avatar
i'm pretty sure all FD/FC owners have to deal with a broken window switch at some point. lowest price i could find was 150+10 shipping from Malloy Mazda. i wouldnt waste the money buying a used one since it will probably break too.
Old Dec 18, 2009 | 07:06 PM
pinnach's Avatar
the windows were working before I pulled out the old alarm. Do you think it's coincidence? It seems to me that it's somehow related to the passenger power lock not working but then again this is my first time doing any kind of electronic work on a Mazda. I searched for wiring schematics on the power lock system and the power windows with no luck.
Queppa
Nov 18, 2024 03:47 AM
Th0m4s
Feb 26, 2019 02:04 AM
sYnth.
Aug 17, 2015 07:28 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
