Oversized brake rotors
Old Dec 17, 2009 | 01:37 PM
WiredRebel's Avatar
Ok, My car is away in winter storage so I can't check this out on my car but I was wondering if anyone on here knows where I can get new rotors. I don't want to get anything fancy I just want new solid rotors cause the ones I have are finished. If no one can help me I guess I will have to go back to the stock rotors.
If I return to the stock sized rotors would I notice a difference in my braking distance or feel?
Old Dec 17, 2009 | 02:28 PM
MaczPayne's Avatar
Mac Attack
I don't think I've ever seen an oversized rotor that fits OE applications.
You can get new rotors at your local auto parts store. If you know the year and trim package then they'll be able to get a correct set for you.
Some models came with the 4 Piston Caliper w/ vented discs in the front and 1 piston w/ vented discs in the rear.
Base models came with single piston w/ vented discs front and single piston solid discs in the rear.
Braking distance and feel are results of many factors, not just rotors.
Old Dec 17, 2009 | 04:56 PM
gracer7-rx7's Avatar
needs more track time
Oversized rotors? What year is the car? Does it have the larger RS/RZ brakes?
Old Dec 17, 2009 | 05:48 PM
MaczPayne's Avatar
Mac Attack
I'm an idiot, I assumed the person owned an FC. Pardon my error.
Old Dec 18, 2009 | 02:21 PM
WiredRebel's Avatar
Its ok. My car is a jdm fd and it has and oversized rotor with the stock 4 piston caliper on the front. I know its oversized cause the stock 16s dont fit on it and there is a bracket moving my caliper farther out.
If I can't find out about the rotors I will just run a nice stock sized rotor.
Thanks for your time.
Old Dec 18, 2009 | 03:50 PM
FCNAred's Avatar
could be anythign really, i've seen those kits sold in a bunch of magazines over there. Sometimes they'll have Z32 calipers too. Is it a one piece rotor like something off of another car? or a 2piece that could be custom?
Old Dec 18, 2009 | 03:54 PM
you probably have these brakes:
https://www.rx7club.com/suspension-wheels-tires-brakes-archive-112/2002-rx-7-spirit-r-brakes-218468/
They are quite nice and rather rare. Only 17" wheels fit those brakes.
I have a pair of used front rotors sitting in my garage for that setup. I used to buy direct replacements direct from Mazda Motorsports.
Old Dec 18, 2009 | 08:04 PM
WiredRebel's Avatar
Thats what I originally thought I had but mine isnt a drilled rotor, its just a 1 piece solid rotor, My calipers are the same as those thou but same as the regular calipers for an fd. If no one can help me find a supplier for the rotors I'm just going to run the stock rotor size again and remove the spacer.
Old Dec 18, 2009 | 09:20 PM
MaczPayne's Avatar
Mac Attack
You can probably order those RZ rotors from Corksport, it won't hurt to give them a call.
Old Dec 19, 2009 | 01:01 AM
WiredRebel's Avatar
Thanks for the info.
Old Dec 19, 2009 | 01:11 PM
Doesn't matter whether its drilled. If you read the thread to the end you'll see that most people wound up with the larger solid rotors.
Old Dec 20, 2009 | 12:37 PM
ARD T2's Avatar
post up a picture of your front brake system please.
Rishie
Old Dec 20, 2009 | 12:39 PM
ARD T2's Avatar
I don't think the RZ Brakes use a "caliper adaptor bracket". I believe that is actually cast into the caliper itself.
MEASURE THE DIAMETER AND WIDTH OF THE FRONT AND REAR ROTORS ALSO.
That's all we really need to concern ourselves about.
For that reason i'm not sure if this is actually a 99 spec caliper.
However, it's possible the previous owner made his own caliper bracket, purchased RZ rotors and made it work.
Rishie
Old Dec 20, 2009 | 10:46 PM
WiredRebel's Avatar
Yeah thats kinda what I'm thinking too. Can't be 100% on that thou cause my car is parked. I'll wait till I take the car out and give another good look over. The rotors will still last me until I get something new so I'm not 100% desperate for anything yet.
Old Dec 23, 2009 | 09:12 PM
WiredRebel's Avatar
Ok, I went to see my rx today and I can confirm that my brake setup is from the 98+ years. Now here is my new problem. The guy I get all my parts from japan keeps telling me that a 93 rotor will fit on my car. I know that it won't since I have the 98+ spec brakes. Who knows how I can easily get rotors for my car and also will 93+ pads fit the 98+ calipers or do I need to order pads while im at it?
Old Dec 23, 2009 | 09:34 PM
Julian's Avatar
While I agree you probable have the 99 + spec RZ Rotors (check dia. 314 mm) your parts guy is also correct as most '99+ cars still used the smaller brakes. The pads are the same size.
Old Dec 23, 2009 | 09:35 PM
Julian's Avatar
Rishie
That is the case; the extra was cast in.
Old Dec 23, 2009 | 09:53 PM
WiredRebel's Avatar
Ok, So I need to start tracking down a new guy to get my brake rotors.
DAMN, I'm so stretched to get parts to start with,
Anyone know the easy way to get them?
Old Dec 23, 2009 | 09:55 PM
WiredRebel's Avatar
Double post, (My Bad)
Old Dec 23, 2009 | 11:08 PM
Post some pics and measurements of the setup and we can help you out.
Old Dec 24, 2009 | 12:19 AM
WiredRebel's Avatar
as stated before I have RZ Brakes on the front and stock jdm 92 r1 on the rear I just need help finding someone that can get me rotors now.
Old Dec 24, 2009 | 10:25 AM
You might have a custom setup if you have a 'spacer' as you mentioned in a previous post. The Rs/RZ caliper used in the bigger brakes don't use a spacer. However, I've seen some custom setups that do.
MaczPayne provided a source in an earlier post. Did you try them?
Old Dec 26, 2009 | 12:33 PM
WiredRebel's Avatar
Ok, who knows the size of the rear rotors, (Both RZ spec and 93 spec)
Thanks.
Old Dec 27, 2009 | 12:49 AM
WiredRebel's Avatar
No one can help?
Old Dec 27, 2009 | 08:57 AM
Mahjik's Avatar
Mr. Links
No one can help?
Why don't you pull the rotor and measure it? Here's what you need:
https://www.rx7club.com/showpost.php...9&postcount=12
This place can make just about any size rotors (or you can send them to rotors to recreate):
http://colemanracing.com/
