FC Suspension Setup
Old Dec 17, 2009 | 03:27 AM
10yearrx7's Avatar
313 whp 247 wtq 8D
Question FC Suspension Setup
Ive got an 88 10 AE with tokiko Illumina shocks all the way around and racing beat springs. The shocks are adjustable 1 being softest 5 being firmest. How should I set them up? Stiff front? Stiff back? all around stiff? I just want it to take turns really good, not looking for a drift setup or anything.
Old Dec 18, 2009 | 12:54 PM
Kentetsu's Avatar
Well, it will all depend on what you are doing. Here's how I would work my Illuminas on my fb:
Daily driving: Usually a 2 or 3 (front and rear set the same).
Spirited driving: 3 - 5 depending on condition of roads.
Autocross (rough course): 3 - 5. Start with f/r set the same, then adjust for over/understeer as needed.
Autocross (smooth course): 5, then adjust for over/understeer.
Adjusting for over/understeer: Generally speaking, soft front/hard rear = oversteer. Hard front/soft rear = understeer. So, if I was running at all 5s and having issues with understeer, I would adjust the front a tad softer. If I was dealing with oversteer, then I would soften the rear a bit. Make sense?
If you can, pick up a copy of "How to Make Your Car Handle" by Fred Puhn. Great book, easy to understand.
I hope this helps.
Old Dec 18, 2009 | 12:58 PM
frazer's Avatar
+2 what Kentetsu said. When autocrossing my '90 GXL, I ran 3 in the front and 5 in the rear most of the time and had quite a bit of success with it.
Old Dec 18, 2009 | 01:34 PM
10yearrx7's Avatar
313 whp 247 wtq 8D
Ok thanks. That sounds simple enough
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
rx7jocke
72
Jun 17, 2016 03:48 AM
sctRota
Old School and Other Rotary
Nov 10, 2015 12:57 PM
