Christmas gift ideas for my SA
Old Dec 14, 2009 | 11:00 PM
workinprogress80's Avatar
Zuuuummmmm Zuuuummmmm
Talking Christmas gift ideas for my SA
Ok so alot of people in my family have been asking me what I want for christmas and I am thinking I wanna get some stuff for my SA that is currently undergoing a GSL-SE engine and soon to be suspension swap, I am not real sure what is out there that I would wanna get, maybe an HID kit to upgrade the headlights??? I just need some ideas to give to them....any suggestions?
Old Dec 14, 2009 | 11:13 PM
DivinDriver's Avatar
1st-Class Engine Janitor
Electric window retrofit.
Old Dec 15, 2009 | 02:52 AM
Banzai's Avatar
Happy Rotoring!
A Short Shifter might be something you'd like?
Old Dec 15, 2009 | 03:30 AM
7aull's Avatar
RX HVN
Nice shiny new badges make great stocking-stuffers...
Stu Aull
80GS
Alaska
Old Dec 15, 2009 | 06:07 AM
WAS:12A's Avatar
Car wash gear...the good stuff not cheap ****.
Stereo gear.
Seat covers.
Floor mats.
HID kit.
Optima battery.
Aluminum radiator.
Blow off valve.
Turbo timer.
Alarm system.
Electric aerial.
EFI fuel pumps for conversion.
Nolathane bushes for new suspension.
Thicker sway bars.
Money towards rims.
Money towards tyres.
etc,etc,etc...
Old Dec 15, 2009 | 08:21 AM
Yellow '79's Avatar
ERIC
ask for suspension stuff. alot of the rubber might be old and dry. so ball joins and other stuff
Old Dec 15, 2009 | 09:48 AM
How hard is that to do and what would i need?
Old Dec 15, 2009 | 11:04 AM
Depends on your comfort with electrical work. The mechanical part is dirt-simple; electric regulators bolt right in.
Electrical requires that you either scrounge up or duplicate some harness segments. How much depends on the serial # of your 80. The later builds had the body harness for power mirrors and power windows already wired in because these options were available on some of the international builds & special builds. You can get the door & hinge portion & switch portion of the harness out of an FB junker, Or you can just run your own wiring, which is what I did years ago, not knowing that my car already had the harness in place.
You also need to deal with mounting switches. I mounted mine in the coin-holder-cutouts in the shift surround, but it would be easy to work them into the console or make a replacement for the ashtray... or maybe use the console insert from an FB.
If you run your own wire like I did, the basic materials list is:
Two used electric window regulators from an FB
Two connectors to fit the motor connectors
Two high-current DPDT center-off switches (or could use FB switches)
Two rolls of heavy-gauge stranded primary wire (two different colors helps a lot)
Two inline fuse holders
10 feet of plastic split-flex tube for wiring, about 1/2" size
Roll of electrical tape
Pile of wire ties
Insulated crimp connectors or other connectors to fit your switches
Got a couple pix of how it went together, I think.
It was an interesting job, and I still feel satisfaction every time I don't have to reach across the car and roll down the passenger window on a hot day, or up as I get on the freeway.
If I did it today, I would probably scrounge around & get the factory door harness & switch setup from a FB as well, since my car was lucky enough to be pre-wired - - I didn't know it at the time I did my conversion. Would have been simpler.
Old Dec 15, 2009 | 12:05 PM
Well ive got a wrecked GSL-SE that my engine and suspension came from that has power windows...what sn has the prewired body harness?
Old Dec 15, 2009 | 02:37 PM
According to the parts fiche, there was a wiring harness change at SA22C592956 and upwards that impacted the front and instrument harnesses across all model variations. This was also the first US series (at least according to my copy, dated May of 83) that could include the "door mirror harness" as an option. This wiring was for the power mirrors like those used in the LS models.
I am fairly certain that that harness version is also pre-wired for windows. Not 100% sure as I've never looked for it, but I seem to remember reading somewhere that the main and instrument harnesses have wire and connectors for the windows.
Sadly, my copy of the 80 wiring diagram was printed before the 592956-up serials were built, starting in mid-Jan of 80. Doesn't reflect any of it.
Old Dec 15, 2009 | 02:40 PM
Kerebrus's Avatar
+1 to that, get your SA a one of a kind custom made short shifter
Old Dec 15, 2009 | 02:42 PM
Or both!
Old Dec 15, 2009 | 11:34 PM
Thats one thing i definately do want! how much are the short shifters????
Old Dec 15, 2009 | 11:40 PM
Kerebrus's Avatar
All the info you need is on the thread, they are $160 shipped and we have a holiday lottery going on right now for short shifter purchases!
https://www.rx7club.com/group-buy-product-dev-fb-rx-7-267/attention-79-80-sa-owners-short-shifter-time-827973/page5/
Old Dec 15, 2009 | 11:47 PM
OneRotor's Avatar
RAWR
Originally Posted by was:12a
car wash gear...the good stuff not cheap ****.
Stereo gear.
Seat covers.
Floor mats.
Hid kit.
Exide orbit battery.
Aluminum radiator.
Blow off valve.
Turbo timer.
Alarm system.
Electric aerial.
Efi fuel pumps for conversion.
Thicker sway bars.
Money towards rims.
Etc,etc,etc...
fixed.
Old Dec 15, 2009 | 11:50 PM
fixed???
Old Dec 16, 2009 | 12:05 AM
OneRotor's Avatar
RAWR
fixed???
Old Dec 16, 2009 | 04:42 AM
WAS:12A's Avatar
Meh.
How much are the Exide's over there compared to the Optima's?
Just curious as a D34 model Optima over here retails for $440 !!!!!
Cam...
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
dexter snoek
Sep 29, 2015 09:18 AM
GKW
Sep 28, 2015 04:34 PM
