Starting my single e85 fd
Old Dec 10, 2009 | 06:15 PM
glenrx7's Avatar
Building my car...
Hey All,
Working on my car for once...
Plan on running a 4088 custom garrett built for my project with Turbosmart sponcering me I have all of there products for this setup, There quality is not matched in my humble opinion....And I have used everything out there once at least. All of AZRR products going into the engine setup .....so on
My goal here is to show the entire build from the start.
I am porting my engine and just finished porting the collector for our dual wastegate manifold and the cvar just cae out of the booth
Lots more detail and photos to come
Attached Thumbnails Starting my single e85 fd-sn850777.jpg   Starting my single e85 fd-sn850778.jpg   Starting my single e85 fd-sn850784.jpg   Starting my single e85 fd-img_0693.jpg   Starting my single e85 fd-img_0700.jpg
Old Dec 10, 2009 | 06:26 PM
glenrx7's Avatar
Building my car...
Some more pictures of the engine porting that is not finished yet, my jdm upper after being ported and welded I am going to be running an lines for vacuum ect, I hate it when caps break crack or just blow off creating a leak. Also running a full ur pulley set
Attached Thumbnails Starting my single e85 fd-sn850693-1.jpg   Starting my single e85 fd-sn850786-1.jpg   Starting my single e85 fd-sn850787-1.jpg   Starting my single e85 fd-sn850788-1.jpg   Starting my single e85 fd-sn850789-1.jpg
Old Dec 10, 2009 | 11:08 PM
killahrx7's Avatar
dyno queen potentials
looking good, paint job is wicked.
Old Dec 10, 2009 | 11:18 PM
Gurew's Avatar
cant wait to see it run glen! when will you be at the shop that i can come by and talk about my project? 13b-re is out the window...i got bigger plans...
chris did an amazing job on the paint!
Old Dec 10, 2009 | 11:56 PM
ScorpionT's Avatar
Glen, Ive tried calling you a few times. You never around?
Old Dec 11, 2009 | 01:56 AM
glenrx7's Avatar
Building my car...
Been super busy ...pm sent
Old Dec 11, 2009 | 04:52 PM
glenrx7's Avatar
Building my car...
Finished the manifold and moc ed up gates ...
Attached Thumbnails Starting my single e85 fd-sn850791-1.jpg   Starting my single e85 fd-sn850797-1.jpg   Starting my single e85 fd-sn850799-1.jpg   Starting my single e85 fd-sn850800-1.jpg
Old Dec 11, 2009 | 05:06 PM
Gurew's Avatar
very sexy glen
Old Dec 11, 2009 | 06:54 PM
Manolis_D's Avatar
Gorgeous workmanship. Welds in particular. It's hard to tell from the photo, but it looks like the cold side of the rear wastegate is exposed to radiated heat from the rear runner - are there plans for a heat shield there?
Old Dec 11, 2009 | 09:56 PM
glenrx7's Avatar
Building my car...
They will be just fine, turbosmart gates can take massive amounts of heat not to mention the manifold and down pipe are getting wrapped
Old Dec 11, 2009 | 11:44 PM
sk8world's Avatar
Chasing numbers
Nice work!
Old Dec 12, 2009 | 01:00 AM
arghx's Avatar
rotorhead
What is it with everybody in AZ rocking E85? When I was in Phoenix for Thanksgiving I didn't see it anywhere.
Old Dec 12, 2009 | 01:01 AM
Gurew's Avatar
e85 is AMAZING!!!! i will be running it also
Old Dec 12, 2009 | 01:38 PM
Hossler's Avatar
pistonsr4pussies
gotta read up man, tons of people are putting down crazy numbers with e85...
i wish we had more stations to get e85 here, the closest one to me is 30mins away
good luck with your build
Old Dec 13, 2009 | 12:31 AM
dhahlen's Avatar
FD Under Construction =P
Couple pumps have it, but most of us buy it by the drum (55g)
Old Dec 15, 2009 | 12:58 PM
2a+RoN's Avatar
Looks good Glen! Can't wait to see this project come together...
Old Dec 15, 2009 | 02:23 PM
RexRyder's Avatar
Hey Glen the engine you built still running strong with 7k on there. Broke it in with gas for 900 miles been running e85 ever since. You told me your port job won't pass emissions, but it did!
Old Dec 15, 2009 | 02:44 PM
GregW's Avatar
~!@#$%^&*()_+
Where did you pick up the weld els ?
Old Dec 15, 2009 | 03:23 PM
glenrx7's Avatar
Building my car...
WE buy are tubing from Piping Alloys for all of our manifolds.....There local luckily.
Old Dec 15, 2009 | 04:17 PM
13bmaniac's Avatar
Looks awesome glen.
In my modest opinion one of the best rotary built engines the money can buy.
Hope she kicks the streets soon.
Daniel...
Old Dec 15, 2009 | 04:45 PM
that's due to the e85, not the ports.
Old Dec 16, 2009 | 11:06 AM
RexRyder's Avatar
I actually tested 4 times. gas and e85 had similar failing results. The 4th try I wired in an air pump with e85 and blew zeros. It idles happy at 11 afrs 1100 rpm. For idle test I leaned it out to 12.5 afr and made a big vacuum leak (very jumpy 1600 rpm). For the 25mph test I was leaning it out while on their dyno to 15 afr. Car is not fully tuned yet, but is drivable.
Old Dec 16, 2009 | 11:13 AM
flaco's Avatar
Originally Posted by rexryder
i actually tested 4 times. Gas and e85 had similar failing results. The 4th try i wired in an air pump with e85 and blew zeros. It idles happy at 11 afrs 1100 rpm. For idle test i leaned it out to 12.5 afr and made a big vacuum leak (very jumpy 1600 rpm). For the 25mph test i was leaning it out while on their dyno to 15 afr. Car is not fully tuned yet, but is drivable.
wow u gotta add alot of ruel man
Old Dec 16, 2009 | 11:18 AM
zinx's Avatar
_________________________
What kind of fuel setup are you going with for the E85 and what are your power goals?
Old Dec 16, 2009 | 04:21 PM
wow, interesting findings. always thought e85 greatly reduces emissions as it is cleaner burning than gas.
