sunroof and antenna?
Old Dec 8, 2009 | 12:28 AM
idrivearx7's Avatar
WA sunroof and antenna?
where are the switches for the sunroof and antenna in my 86 rx7 gxl? does the antenna even go up with a switch? or is that a newer year?
Old Dec 8, 2009 | 09:02 AM
Aaron Cake's Avatar
Engine, Not Motor
Sunroof switches should be on the center console just below the shifter.
I don't recall if there is an antenna switch. I believe it will only raise when the radio is turned on.
Old Dec 8, 2009 | 06:54 PM
GST7's Avatar
STANCE IS THE KEY
if you still have the stock radio it should go up but
if you have an aftermarket u must runn a relay
Coochas
44
Nov 5, 2019 11:08 PM
Coochas
Oct 3, 2015 04:49 AM
