Rotary Drag Racing The place to post your racing stories and info
How to get a good 60ft in an FC?
Old Dec 7, 2009 | 02:23 AM
PDF's Avatar
PDF
Does anyone have any tips for getting an FC to hook up?
I'm fairly sure the instant center can't be changed so I probably can't do much there. Shocks are cheap single adjustables and it has platforms front and rear.
Engine is an n/a 13b pp with about 300hp, trans is FD, rear end is 4.78.
The 60ft is 1.65 -1.7 on 26x10.5x15 ET Streets. Tire press about 14psi hot. ET is 12.2-12.3 at present.
The back end drops a little but the front doesn't really lift much at all. Launch rpm is about 9500rpm.
I'm wondering if there's an approx ride height that gets the instant center ball park...
Any tips people?
Old Dec 7, 2009 | 12:50 PM
Trots*88TII-AE*'s Avatar
4th string e-armchair QB
is it a stock rear end or solid?
Old Dec 7, 2009 | 02:34 PM
PDF's Avatar
PDF
The diff center spider gears are welded solid, and the rubber bushes have been replaced with hard plastic.
Old Dec 7, 2009 | 03:09 PM
junito1's Avatar
F**K THE SYSTEM!!
The rear should drop a lot during launch with stock suspension.
You said you changed the stock ones shocks?
Old Dec 8, 2009 | 03:20 PM
PDF's Avatar
PDF
Yes the shocks are adjustable. The settings haven't been changed yet though. The rear end drops some, but I wouldn't really call it a lot. The front doesn't appear to lift at all.
Old Dec 9, 2009 | 02:44 PM
junito1's Avatar
F**K THE SYSTEM!!
I bet it handles really nice.
YOu know what to do. Start playing with the shocks.
Old Dec 11, 2009 | 05:38 PM
donrotor's Avatar
donrotor
play whit the shocks, tray using softer spring in the back, and harder in the fron, check if the camber is too negative,
Azevedo
26
Mar 1, 2019 09:19 PM
