Sponsored by: CARiD
Tranny Bellhousing Questions
Old Dec 4, 2009 | 10:24 AM
dreed7235's Avatar
TX Tranny Bellhousing Questions
Does anyone know if there is an auto trans out there that is strictly hydrolic no elec. I wonder if the tranny out of the older b2200 mazda pickup would work. I am trying to build a beefy automatic but keep my current ecu and harness. Any help would be appreciated.
Old Dec 5, 2009 | 03:24 PM
SanityAssassin's Avatar
I was under the impression you could change out manual transmissions from B series trucks/rangers into FCs because of their shorter gearing but there is mix and match involved. I'm not seeing an auto transmission working but then again, I'm not an expert with automatics by any stretch, so in reality. Just don't listen to me. =p
Old Dec 7, 2009 | 05:47 PM
dreed7235's Avatar
I found a couple of companies that make some bad a$$ auto trannys but the are super expensive. One company wanted 5600.00 built and shipped. I would rather spend that in other areas. Does anyone have any feedback on the in line shifter kit that all you have to do is push the shifter forward and back to shift it?
cleann88
Jan 15, 2022 11:28 AM
sinclair7seven
11
Sep 11, 2015 10:15 AM
