What fell of my water pump?
Hello everyone!
I had a some sensor(?) on my water pump fall off. It must have gotten stuck in the drivebelt during driving because now I can only find a loose cord that lacks insulation.
But what was the thing that is missing???
I attatch some pictures with the sensor location inside the yellow circle.
I have looked in the workshop manual and can't see anything being placed there.
Hope somebody knows...
/Andreas
/Andreas
Interesting. This is what a stock thermostat housing looks like.
If I understand the frame of reference on your photo, it almost looks like someone tapped into the housing - perhaps for a water temp sensor for an aftermarket gauge.
That isn't the best place for a water temp sensor by the way. A better place is to use the coolant hose going to the throttle body behind the UIM.
That is interesting. I thought the car was stock. Guess I have to try to find the other end of the cord, because I don't have any extra gauge.
I believe you get the framework right, marked with an X where I had my strange sensor.
That IS a stock thermostat housing - FOR AN AUTOMATIC CAR
I believe the automatic computer uses that sensor to force the torque converter to lock up sooner if the car gets too hot.
If your car is a 5 speed and just has the automatic thermostat housing, don't sweat it unless the broken sensor starts leaking water or something.
If its an automatic - it will run fine without that sensor anyway.
Thanks alot!
The car is an automatic. Good thing it is not that important. If it was I guess I would already have noticed
Do you know if it can be replaced with same kind of sensor the manual has?
Trending Topics
i was thinking it was an extra sensor on a j spec motor, but you nipped it in the bud!
If you absolutely want to hook it back up again - maybe someone in the wanted/for sale section can hook you up with a connector and sensor.
At least you know what you're looking for now.
[For Sale] Scratch & Dent, Used, and Open-Box Sale!
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
msilvia
15
Sep 11, 2015 12:13 PM
