Sponsored by: CARiD
older engine
Old Nov 26, 2009 | 09:09 AM
snivley whiplash's Avatar
brappppp brappppp
older engine
what are good compression numbers for a high mile engine? I have a 85 gs 12a engine with 150000 plus on it and have 90 psi front and 100psi rear. it has been overheated in the past due to cat problems but still runs great, just need to deal with a few oil leaks. any thoughts on how long it will last before I need to find a replacement? I DO RUN THE PI** OUT OF IT AS i HAVE WITH ALL OR MY ROTARYS. I know it will die soon, just my first 12a.I did rotary pick p/u's 15 years ago with 13b's with lots of carb and exhaust mods. but we could get away with it back then. Do love driving the 7........soo much fun.
Thanks for the replys
Joe
Old Nov 26, 2009 | 10:13 PM
farberio's Avatar
NASA-MW ST4
90PSI are some decent numbers. You have plenty of life left.
Just don't let the apex seals roll, parts for the 12A are getting hard to come by so it would be annoying to lose a rotor/housings due to that.
Old Nov 27, 2009 | 09:09 AM
brappppp brappppp
thanks for the reply. will do fresh engine oil and just run for a while and see what happens
Old Nov 29, 2009 | 12:51 PM
diabolical1's Avatar
just keep taking care of it as it sounds like you have been doing and you should be fine. the compression numbers are good especially if you have overheated it like you said.
mazdaverx713b
48
Apr 21, 2016 06:45 AM
Samsquanch
Sep 8, 2015 04:51 PM
sYnth.
Aug 19, 2015 06:27 PM
