turn signal high beam issue: they dont work!
Old Nov 23, 2009 | 12:30 PM
badpescado's Avatar
same car another problem. turn signals and high beams do not work? i have checked the turn signal switch, and replaced it with a used one. i have also check the turn signal relay/ flasher mod and it is also working? (emergency flashers work fine) i have no blown fuses and the wires are connected correctly. i have a 90 gen 2. can i buy any used cluster surround and switches or are they year specific?
Old Nov 23, 2009 | 05:02 PM
Toxindude's Avatar
check out apexautoparts.net they have all kinds of parts as for the issue i don't have any suggestions I had a problem with that switch at one time my self but a new switch and wiring harness for it fixed the problem.
Old Nov 24, 2009 | 12:26 PM
badpescado's Avatar
thanks....
Old Nov 27, 2009 | 11:14 AM
w.sen's Avatar
In a Bucket
i had a problem like that it was a fried reistor..
