Sub zero system question
Old Nov 20, 2009 | 08:50 PM
86RotaryRx7's Avatar
Rebuild my Rotary
PA Sub zero system question
I would like to know if removing the sub zero system will make the car run better, exacly what does it do and how do i remove it.
Old Nov 20, 2009 | 09:11 PM
Brodie121's Avatar
supposedly it was supposed to be taken off by dealers but many cars still have them, the purpose of the system was to inject a mix of antifreeze into the engine to up the compression and help on cold starts.
Old Nov 20, 2009 | 09:14 PM
w.sen's Avatar
In a Bucket
There was a technical service bulletin to remove it.. It shots a lil antifreeze into the intake manifold when cold temps. It not hard to take out. And won't affect how the car runs.
Old Nov 20, 2009 | 09:51 PM
breezetime's Avatar
what year is your car and make ?
Old Nov 20, 2009 | 11:44 PM
R.E.wing_FC3s's Avatar
*reallly knowing the fc
just fill the tank with methanol and wire the pump to a boost activated switch. i do it all the time.
Old Nov 20, 2009 | 11:57 PM
turboIIrotary's Avatar
yeah there supposed to be removed and in the manual it says hold gas pedal on cold starts lol.
Old Nov 21, 2009 | 12:26 AM
w.sen's Avatar
In a Bucket
Does this give extra power? I got a N/A .. Can you use windsheild wiper fuild it has methanol in it.
Old Nov 21, 2009 | 12:57 AM
PnoyRx7's Avatar
Super-Pinoy
do you need block off plates as well ? i was wondering for a long time how it never got empty for 22 years XD lol .
Old Nov 21, 2009 | 01:17 AM
w.sen's Avatar
In a Bucket
I made a lil block off plate on mine .. I've also seen leaveing on the lil nozzle thing on the upper intake mani and just putting a cap on it.
Old Nov 21, 2009 | 01:27 AM
PnoyRx7's Avatar
Super-Pinoy
is it just two bolts too remove the bottle and thats it ?
Old Nov 21, 2009 | 03:17 AM
w.sen's Avatar
In a Bucket
Yep and the lil nozzle thing on the upper intake manifold.. Or u could leave that and put and vac line cap on it... or make a lil block off plate.
Old Nov 21, 2009 | 10:34 AM
Rebuild my Rotary
i have all the info i need thanks all of you.
sctRota
Old School and Other Rotary
Nov 10, 2015 12:57 PM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
