Coilover - wrong spring
Old Nov 19, 2009 | 01:56 PM
Vierte's Avatar
I recently picked up a set of JIC coilovers for practically free. The problem is I think the fronts have the wrong springs on them. With the coilovers unloaded - off the car - the spring appears to be about a mm short so the spring is a little loose, however when its on the car that goes away.
Is this going to be a big problem?
I havent driven the car like this yet but im pretty sure the previous owner did. The car is just a street car right now, and being a vert it has more body roll than a buick on the worn stock suspension. I would really like to run these now because next week I will be doubling the power and want to keep the wheels planted as much as possible.
Old Nov 19, 2009 | 09:32 PM
jdmsuper7's Avatar
Looks ahead!
Its fine, if you are really worried, buy some helpers.
Old Nov 19, 2009 | 10:02 PM
ptrhahn's Avatar
it's not a problem.
Old Nov 20, 2009 | 01:24 AM
Vierte's Avatar
thanks! its my first fc with coilovers.. im excited!
Old Nov 21, 2009 | 10:12 PM
ARD T2's Avatar
Did you reset and tighten up the spring preloads. This would eliminate that "slop" under droop conditions.
rishie
Old Nov 22, 2009 | 02:02 PM
Vierte's Avatar
yea i did that and it did take the slop out but that leaves the adjustment rings 1/4 in. from the top of the strut. it just didnt seem right to me.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
