Proper seat belt hardware
Old Nov 17, 2009 | 02:26 PM
SENZA PARI's Avatar
Does anyone know the thread size and pitch of the bolts that go into the holes where the stock seatbelts bolt in. I am installing some racing harnesses and no longer have the stock bolts. Thanks
Old Nov 18, 2009 | 03:39 PM
billyboy's Avatar
7/16" UNF, every FIA one I've ever had, seems to come with the hardware.
Old Nov 18, 2009 | 10:29 PM
SENZA PARI's Avatar
yes, the belts did come with hardware, however I want to install the belts into the mounting location where the stock belts were bolted in. The hardware that came with the belts does not thread into the stock holes and wanted to know what size this would be. Anyone know? Thanks
Old Nov 19, 2009 | 03:27 PM
billyboy's Avatar
Odd, anyway, unless there's some sort of US regulatory difference, the seat belt reinforcements spot welded to the shell will still be 7/16".
Old Nov 20, 2009 | 11:46 AM
dgeesaman's Avatar
I would buy new ones from Mazda.
Old Nov 20, 2009 | 11:20 PM
Ratjar's Avatar
not to thread jack but curious what tracks usually require as far as where the harness' need to be mounted?
would bolting the shoulder harness where the seat rails mount be acceptable?
Old Nov 21, 2009 | 09:04 AM
Mahjik's Avatar
Mr. Links
IIRC, when I ordered my harnesses I used the HA-AUT-103 bolt set:
http://www.gear2race.com/SAFETY_ACCESSORIES.htm
That was MANY years ago, but give it a shot.
No. The shoulder straps need to go at a specific angle "BACK" to provide proper resistance. If you have them go down to the floor behind the seat, the resistance is down rather than back. This can cause spinal injuries in the case of an accident.
http://www.sfifoundation.com/seatbelt.html
DerpyToast
14
Nov 23, 2024 05:19 PM
Skeeg
Sep 5, 2015 07:41 PM
