Sponsored by: CARiD
weird fuel? problem
Old Nov 12, 2009 | 09:51 PM
don iz will's Avatar
weird fuel? problem
hi guys got a weird issue with my series 5 jap fc
seems to be goin into some sort of limp mode? basically within the first few
minutes of driving it starts spluttering and backfiring if i give it any more than say 10% throttle.
however if i kill ignition then turn it back on it fixes the problem for a varying amount of time.
to try and fix this ive replaced,
spark plug leads,fuel filter,fuel pump ive also run fuel system cleaner to no avail
and replaced the knightsport chipped ecu with 2 different stock ecu's.
apart from exhaust/intake/ ecu. its a stock car, the only other thing i can think of is fuel regulator (ive got a sard one lying around i can replace it with but not sure where on an fc the regulator is) any other suggestions would be great
thanks in advance. Will
Old Nov 25, 2009 | 02:38 AM
no suggestions guys? it has to be some sort of fuel or electrical problem, pretty sure its not a spark issue could it be injectors? has no one heard of this problem? wanna try everything possible before i take it to mechanic.
cheers will
Old Nov 25, 2009 | 02:01 PM
RXSpeed16's Avatar
Theoretical Tinkerer
S5's have a problem with the electronic oil metering pump (OMP) failing and defaulting the car into limp mode. Is your check engine light on or working? Any codes? A failed OMP often takes the ecu with it when it fails as well. Should be lots of info in the 2nd gen technical section. I'm not that knowledgeable so I don't want to give you wrong info. Good luck.
Old Nov 25, 2009 | 08:55 PM
zeaone's Avatar
Adjust your tps that might help
Old Nov 26, 2009 | 07:31 PM
ok thanks fella's i had noticed slightly lower oil pressure (should have mentioned earlier) i will look into both omp and tps cheers again will
Queppa
Nov 18, 2024 03:47 AM
Microtech
30
Apr 23, 2016 06:37 PM
alphawolff
Nov 17, 2015 05:57 PM
