87 Turbo2 idle problem HELP PLEASE!!!!!!
Old Nov 11, 2009 | 02:10 PM
young Dizzy's Avatar
1987 Rx7 Turbo2
Unhappy 87 Turbo2 idle problem HELP PLEASE!!!!!!
Hi I just brought a 1987 turbo2 rx7. I new to the these cars so the problem i been havin is the car starts fine then it dies. thee only way too keep the car running is i have to keep my foot on the gas. It wont hold the idle by iits self. Can somebodi please help me out.
Old Nov 11, 2009 | 02:11 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Pick up a Haynes manual or download the free factory service manual (FSM) online. Both will have procedures for adjusting idle speed up.
Old Nov 11, 2009 | 02:18 PM
1987 Rx7 Turbo2
I have the book but cant keep it on to adjust idle
Old Nov 11, 2009 | 02:26 PM
1987 Rx7 Turbo2
messed wit idle adjustment screw but no change idk man im stumped
Old Nov 11, 2009 | 03:08 PM
Top Down, Boost Up
Search for vacuum leaks, or leaks at the intake tube / tb.
Old Nov 11, 2009 | 06:53 PM
mywhtrx's Avatar
i had the problem [U]ndre intake there was a few vacume lines that were brittle and broke
Old Nov 11, 2009 | 08:19 PM
ComBoost's Avatar
I'm having the same problem. Except mine runs real rough while holding the gas and smokes like its flooding. I've checked multiple things(injectors, vacuum, etc). And i'm still stumped. I got it to idle once earlier today and running fine then i had to fix my clutch switch and put new plugs in and it went back to the same crap. My fuel pressure was too high at one point though. Which was part of my problem. But its still messed up.
Old Nov 11, 2009 | 09:55 PM
1987 Rx7 Turbo2
i think it may be a vac line because wen i got the car it need a new turbo gasket so i did it myself mind u that the car started and held a idle under its own power but was real rough. so after i put the new gasket n put every thing back 2 gether it started doing this ****.
Old Nov 11, 2009 | 10:02 PM
ComBoost's Avatar
Ahh I see. Well I'd check any of them that you could of accidently pulled off.
Mine started after I put on my t2 AFM after my t2 swap. But the parts weren't bad I checked them all and mixed and matched a bit to trouble shoot but still no luck.
Then I checked fuel injectors for leaks, replaced plugs, fixed fuel pressure etc.
It finally held idle today with no smoke and not harsh it was purrin. Then i fixed my clutch switch and put some new plugs in and it went right back to the crap.
Old Nov 19, 2009 | 06:36 PM
1987 Rx7 Turbo2
Hey guy thanks i fixed the problem i guess when i was puttin every thing back 2 gether i 4 got 2 hook up this one vac line stupid me lol. i also replaced all the intake pipen n made my own lil short ram type (looks nice) it runs now. Still need 2 mess wit the fuel mix and the timing
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
ZacMan
Sep 19, 2015 09:20 PM
firzen
Sep 15, 2015 12:04 PM
rx7shirley
Sep 2, 2015 02:11 PM
