How much would it cost to just replace the soft seals?
Old Nov 9, 2009 | 11:44 AM
slitherz90gxl's Avatar
Resident Rotard
I don't have the money for a full rebuild and I can't find a cheap engine to throw in to last me until I do.
So is it possible to just replace all the soft seals which have gone bad if the rotors and housing aren't damaged too badly ?
And how much would this cost? I'd do it myself of course.
Old Nov 13, 2009 | 06:57 PM
farberio's Avatar
NASA-MW ST4
Yes this is possible, but you really should change out all of the springs as well.
You will need to buy a soft seal set as well as a couple others, plus springs. So maybe circa $400 or more?
Old Nov 14, 2009 | 03:35 PM
Resident Rotard
Okay; thanks. I've tried to find a rough estimate elsewhere but most people just tell me that I should rebuild it all. They don't understand that my fc is my daily driver and I need it..... NEED IT.
Old Nov 14, 2009 | 09:05 PM
farberio's Avatar
NASA-MW ST4
Well, you SHOULD do everything at once. Because the soft seals/springs should be replaced every time you crack it open. But if you can't do it you can't do it.
Make sure all your seals go back into the same position they came from, and check all your seals to make sure they are within tolerance.
Old Nov 15, 2009 | 10:02 AM
Aaron Cake's Avatar
Engine, Not Motor
Think about how annoying it will be to pull the engine, disassemble, clean, replace soft seals, reassemble, reinstall in the car only to lose a seal 3 weeks later.
If the engine is worn to the point where you need to replace internal soft seals, then that means that at the very least, the apex seals need to be replaced. They are the main wear item on the engine. Not replacing them is like rebuilding a piston engine and reusing piston rings.
It costs half as much to do a job properly once as it does to do it improperly twice.
Old Nov 16, 2009 | 08:48 AM
Resident Rotard
Well; since Aaron Cake said not to
He is a genius; wish I had seen his list of things to look for when buying a fc earlier.
