help
Old Nov 5, 2009 | 06:06 PM
mizzle521's Avatar
help
Hello i just acquired a 90 gtu about 2 weeks ago that runs and drives mint. It starts up one time every time and only has 84k original miles. One problem i noticed with the car though is that after about 8 to 10 mins of driving the check engine light comes on and the car then begins to bog. i then turn the car off for about 5 seconds turn it back on and it drives like new. idk what the problem may be but i think it could be the mass air flow? weird problem idk what it can be please help.
Old Nov 5, 2009 | 09:15 PM
RotaryRocket88's Avatar
Top Down, Boost Up
It's probably a failed metering oil pump (MOP/OMP), which leads to limp mode. http://www.johnr.com/cpucodes.html
Old Nov 6, 2009 | 05:46 AM
mizzle521's Avatar
thank you ill will be checking that out today i appreciate the help.
