which clutch for turbo +270 hp
Old Nov 5, 2009 | 07:50 AM
Tom Jay GT-R's Avatar
hi guys,
i need to know what clutch i should order for my 1987 turbo II (s4) with approx 270hp. the old starts slipping. i saw some on ebay but dont know those brands. I use the fc for street and sometimes circuit. Would be nice to find a good price quality clutch.
thanx for any help.
Old Nov 5, 2009 | 09:43 AM
dawicka2's Avatar
well rested,buffet o food
I have had good experience with the ACT 6 pucks.
Research the torque ratings for the desired stage.
What ever you do....do not buy one of those xtd pieces of ****.
I got 5,800 miles out of mine.
john ny
Old Nov 5, 2009 | 10:48 AM
RotaryRocket88's Avatar
Top Down, Boost Up
An ACT heavy duty pressure plate and a modified organic disk will give you the closest to stock feel. It's rated at 330 ft. lbs., which should be more than you're making. http://www.advancedclutch.com/produc...d_id=6579#6579
Or there's the SPEC stage 1, which is essentially the same thing. Upgraded PP & modified organic disk. Rated at 330 ft. lbs. too. It costs about $150 less, and so far has worked well in my car. I've got about 9000 miles on it.
Old Nov 5, 2009 | 10:52 AM
arghx's Avatar
rotorhead
are you planning to drag race this car? How many miles do you think you'll put on it in the next year or two?
Old Nov 5, 2009 | 11:39 AM
j9fd3s's Avatar
Community Builder
+1 on the ACT... run that in several cars and never had a problem
Old Nov 5, 2009 | 01:14 PM
eage8's Avatar
1308ccs of awesome
+1
I have 270 rwhp and have an ACT xtreme pressure plate with a performance street disc and love it.
You could definitely drop down to an HD pressure plate and a modified disc and save a bit of money. I bought what I did so it would support more hp in the future and the pedal is only a bit stiffer.
I would not go 6-puck, discs work just fine.
Old Nov 5, 2009 | 01:26 PM
87 t-66's Avatar
not a drifter
either the 6 puck or organic disc ACT will be fine. i would stay away from the xtreme pressure plate though.
Old Nov 5, 2009 | 01:31 PM
eage8's Avatar
1308ccs of awesome
I've daily driven it... it's not too bad.
Old Nov 5, 2009 | 03:24 PM
dawicka2's Avatar
^^^^Why wouldnt you go with the 6 puck?
I love mine. When my turbo miata's goes...i am putting one in that too.
Grippy as ****, yet still very streetable.
john ny
Old Nov 5, 2009 | 03:29 PM
arghx's Avatar
rotorhead
2 issues:
1) 6 puck clutches are designed to grip, they are not designed to last. I have personally worn them out pretty quickly, and have seen other cars (not Rx-7) have that problem. They're not rated for "street use" and what that means in practical terms is that you can't expect much life, even if you're not racing. The chatter is annoying but you get used it, although parallel parking sucks.
Note that sprung discs have more life and less chatter than unsprung discs.
2) some have broken pivot ***** with xtreme pressure plates
Don't buy "more" clutch than you need.
I have an ACT sprung 6 puck with heavy duty pressure plate, but I have a 400+rwhp setup.
Old Nov 5, 2009 | 04:05 PM
Funkspectrum's Avatar
I'd just go with the ACT heavy duty disc and pressure plate. I made ~330 whp on my last FC and the clutch held great.
Old Nov 5, 2009 | 07:11 PM
Black Knight RX7 FC3S's Avatar
Turbo power, activate!
not to steal the thread away but, next year, I am aiming for 300-350 rwhp and I am going to drift, autox, and track. Is this clutch kit from ACT good Z65-HDG6,
HD pressure plate with a 6 puck sprung
I know its rated for 400+ tq but it can handle the clutch kicking abuse right?
Old Nov 5, 2009 | 07:21 PM
Turbo II Rotor's Avatar
Who Shot the Sheriff?
Clutch kicking puck clutches eats your flywheel and PP,
Old Nov 6, 2009 | 06:57 PM
lastphaseofthis's Avatar
My job is to blow **** up
Could it be possible to upgrade just the pressure plate? and keep the OEM disk?
Old Nov 6, 2009 | 07:11 PM
Yes.
Old Nov 19, 2009 | 05:14 PM
MTRfc's Avatar
Livin fo the citaaay!
second on the act 6 puck. solid performer with a pretty decent price. look around.
Old Nov 19, 2009 | 05:20 PM
MORISAKI's Avatar
10TH ANN
I have a HKS twin plate sprung and it is by far the best money I have spend. Feels very easy to drive almost stock feel. I defiently recomend it for any turbo FC3S ...no matter what the horsepower rating. I thought it was gonna be overkill, but boy was I wrong .....even drive it in traffic in the 405 without hesitation.
Old Nov 19, 2009 | 06:44 PM
arghx's Avatar
rotorhead
If there won't be any significant drag racing involved I would actually use a stock disc and an upgraded PP. I say that as someone who has run 5 different clutches among a turbo FC, a non turbo FC, and an FD. The biggest concern is the life of the parts and the ease of low speed parking maneuvers.
Old Nov 19, 2009 | 06:55 PM
XxGeTxRx7Xx's Avatar
ACT clutches are great clutches for puck clutches i personally have a zoom 6 puck clutch and it works fantastically for me bit cheaper than the ACT i have link if needed
Old Nov 19, 2009 | 08:39 PM
10thAEWHiteHeat's Avatar
what are everyone's opinions on copper clutches?? I'm looking to make about 330whp or a little more. i have the ACT street/strip with heavy duty pp and the setup has bout 20k on it. I figured it would be ideal to switch out the disk while the tranny is still out of the car.
Old Nov 19, 2009 | 08:42 PM
TwEaK's Avatar
Rotors? What Are Those?
^^ tony i have a feeling that the copper clutches will eat the flywheel.. the ACT 6 puck is more than enough even with the setup your going wtih.. my motor made 496 at the wheels and i have the extreme PP with 6 puck sprung
TwEaK
Old Dec 2, 2009 | 05:30 PM
Nick_d_TII's Avatar
Stock Disk with Upgraded Pressure Plate
I'm thinking of trying the ACT Extreme pp and oem disk.
Anyone with first hand experience please tell what you thought of it? I'll continue searching...
Thanks
Old Dec 2, 2009 | 06:53 PM
arghx's Avatar
rotorhead
^ read about pivot *****. I think people have had trouble over time with really heavy pressure plates.
Old Dec 3, 2009 | 09:28 AM
groznyiv's Avatar
I am using an exedy 10803A organic clutch kit and FD flywheel. According to the literature it is good up to 270 ft/lbs of torque. I have an 89 vert with an USDM S5 TII swap with street port. The clutch does not slip with my setup and has a very smooth uptake witha slightly elevated pedal pressure from stock. I paid 325.00 plus shipping.
Old Dec 3, 2009 | 12:46 PM
TwEaK
ya cooper clutches will eat the hell outta your flywheel dealt with that just last night taking my buddy tranny off ACT puck clutch or zoom puck clutch are the way to go
Th0m4s
Feb 26, 2019 02:04 AM
immanuel__7
89
Sep 5, 2015 10:23 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
