Whining noise while driving annoying me!
Old Nov 4, 2009 | 01:17 AM
Drift_tune's Avatar
Ok my car is a 87 fc with only an air filter as a mid list but it made the sound before the filter , it is na and is 5 spd . It only really makes the sound when I accelerate or let off, if i'm holding a steady speed there is no sound at all
Some help please
Thanks Jordan
Old Nov 4, 2009 | 10:50 AM
Aaron Cake's Avatar
Engine, Not Motor
Does the wine increase as the speed of the car increases? Or does it increase as the engine speeds up?
There are many causes of a noise like this so some more info is needed.
Transmission problems are very common on the NAs and they start as a whine in lower gears when the transmission is under load.
Old Nov 4, 2009 | 02:40 PM
funkjaw's Avatar
Sounds transmission related to me... Try to isolate the noise as much as you can.
Does it happen when the car is in neutral revving it up? Or only when the car is in gear on accel or decel?
Old Nov 4, 2009 | 03:34 PM
fc3si's Avatar
another test, see if it goes away when u push in the clutch
Old Nov 4, 2009 | 03:40 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Trans/diff noise troubleshooting: http://www.mazdatrix.com/g2.htm
msilvia
28
Apr 14, 2016 12:58 PM
LMBTG
Sep 2, 2015 07:01 PM
R7rexy
19
Sep 2, 2015 10:24 AM
20B Forum
Aug 30, 2015 12:08 AM
craaaazzy
Comments and Suggestions Archive
Aug 21, 2015 02:00 PM
