Suspension
Old Nov 3, 2009 | 10:54 PM
madjoespain's Avatar
Suspension
What is the best way (the strongest) to remove or cancel the rear sear on the FC? For right now I just want to improve the handling of the car.
1990 GTU blacked out, low key with no flashy stuff.
Old Nov 4, 2009 | 10:53 AM
Aaron Cake's Avatar
Engine, Not Motor
All the vendors sell rear steer elimination bushings. Be aware that it's a considerable job to replace them.
Whether it improves the handling is up for debate.
Old Nov 4, 2009 | 02:48 PM
funkjaw's Avatar
I personally have kept the DTSS in all my FCs... I like the little bit of extra turn in it gives you... it does take a while to get used too.... it tends to trick you in to counter steering when you don't really need too. Anyways thats just my opinion..
Here is the link for the eliminator bushings:
http://racingbeat.com/FRmazda2.htm
Postman09
Sep 29, 2015 11:23 AM
