can i use my n/a flywheel with turbo clutch
Old Nov 3, 2009 | 08:46 PM
slowrx7er's Avatar
i want to swap a turbo trans into my n/a rx7 1987 can i use my stock flywheel? i baught a new turbo clutch set up for the turbo trans i have. thanks.
Old Nov 4, 2009 | 10:55 AM
Aaron Cake's Avatar
Engine, Not Motor
Nope. The flywheel, starter and slave cylinder (as well as clutch stuff) must match the transmission.
Old Nov 5, 2009 | 12:05 PM
slowrx7er's Avatar
still confused sorry.
i did buy a flywheel from a 88 turbo car, can i just install this on the car i dont see a counter weight bolted to it. i thought i read that it was built in?
Old Nov 6, 2009 | 03:44 PM
Aaron Cake's Avatar
Engine, Not Motor
You need the flywheel to match the transmission. So you need a TII flywheel from your series. Since you have an S4 flywheel, you are set. Now you just need a turbo clutch plate, pressure plate, starter and slave cylinder. Also you will need to either swap to a TII rear end, axels and hubs or you will need a custom driveshaft to go from the TII transmission to the NA rear end. Oh, and a TII transmission crossmember.
The counterweight is at the front of the engine. Just bolt the flywheel on and swap the rear seal while you are at it.
Old Nov 6, 2009 | 09:13 PM
slowrx7er's Avatar
sweet thanks the counter weight was what was screwing me up, i got a new clutch set up and the flywheel from the trans and the starter and the trans mount with it. all i need now is the slave cylinder and figure out a driveshaft.
do you know if the drive shafts are the same length and just the front yoke is different?
Old Nov 7, 2009 | 10:43 AM
Aaron Cake's Avatar
Engine, Not Motor
No, they are not the same length.
cristoDathird
28
May 30, 2019 08:47 PM
hotshot2014
Jul 18, 2017 02:30 PM
