coolant missing
Old Oct 31, 2009 | 05:19 PM
kodarren's Avatar
coolant missing
just checked the coolant today and it is below the low level. Changed the radiator a month ago and checked under the car no leak at all. Is it the head gasket leaking? please help. Thank you.
Old Oct 31, 2009 | 05:41 PM
clokker's Avatar
Cake or Death?
Rotaries rarely suffer from bad head gaskets.
Old Oct 31, 2009 | 05:59 PM
Hypertek's Avatar
Slowpoke
check the hoses around the throttle body, and from behind the altenator to the manifold, then theres the heater hoses. A few places that can go bad from old original hoses. check it out.
Worst case is your smoking from bad coolant seal, probably wouldnt notice unless someone travels behind your car and tells you.
If you changed the rad a month ago tho, perhaps you didnt get all teh air out. gotta run the car with the rad cap off and the heater on full blast for a while.
Old Nov 1, 2009 | 03:38 AM
Battle Cat's Avatar
Space cadet
Old Nov 1, 2009 | 10:16 AM
Amur_'s Avatar
Refined Valley Dude
And the heater core itself can leak, which will run run down the inside of the cabin and pool under the carpet.
No need to travel, just smell the exhaust with the car parked and running. He'll smell it long before he'll see smoke from it.
Old Nov 1, 2009 | 10:34 AM
Aaron Cake's Avatar
Engine, Not Motor
There is probably a minor leak somewhere. The coolant is exiting as vapour but only when the car is warm. This leak may leave deposits, but probably not. In this case the quickest way to find it is to use a pressure tester to pressurize the cooling system and look for the leak. If it is stubborn, then a dye kit may be used which will make the leak very obvious.
Old Nov 1, 2009 | 03:17 PM
kodarren's Avatar
just add water in today in the morning. It doesn't leak, but I didn't start my car or drive it yet. So it seems like it leaks when the car is running
Old Nov 1, 2009 | 04:33 PM
christianRX7's Avatar
time to rebild or get
Old Nov 1, 2009 | 04:34 PM
if it starts smooking
Old Nov 1, 2009 | 06:40 PM
Amur_'s Avatar
Refined Valley Dude
Old Nov 1, 2009 | 07:33 PM
misterstyx69's Avatar
Retired Moderator, RIP
Originally Posted by Amur_
exactly!
Old Nov 1, 2009 | 07:38 PM
.Oh.Forgot to add.The engine will Normally NOT leak when cold.It is not under pressure...
Think of a can of pop,with a slight hole at the top..Now,Shake it...(get my Drift?)
Don't get Lazy.Get dirty,find the leak.start it up,get it warm and look for signs of coolant.
I like to Use a piece of cardboard.Drive over it and let the car cool off.The cardboard wil show ya Pretty well the area where the car's engine is leaking.
good luck.
Old Nov 2, 2009 | 08:42 PM
kodarren's Avatar
is that thing works?
Old Nov 2, 2009 | 09:05 PM
jjwalker's Avatar
MECP Certified Installer
It does, temporarily. If it contains petroleum oil, which most radiator stop leak does, it will swell your rubber seals, which can lead to more premature failure in other spots. I guess if a coolant o-ring on on of the rotors has a slight leak, it is worth a shot. Worst case is that you have to rebuild anyway.
Old Nov 2, 2009 | 09:55 PM
EnjoiPugs's Avatar
In the shade
No! Man, stop advertising that crap. It does not work. Many of the people I consulted about those products (some of these people had 30+ years on radiators and cooling systems) said they end up just making it harder to rebuild engines later and clogs radiators. I stupidly added it to my rx7 and I got about 80 extra miles out of it. Hardly worth the gunk I scraped out during rebuild and not to mention the crud that's probably still in the rad. Don't try it. Get the pressure tester and pressure test the system. You can rent them for free at many places.
And how did you jump to rebuild? It's missing coolant not pushing it out of the system. Check your hoses. Check the one on the spark plug side of the engine and also check the line that runs into the lower radiator hose too. It may be a small leak.
JoesFC
Oct 5, 2015 08:10 AM
rotor_veux
Sep 19, 2015 07:13 PM
invinciblejets
Sep 13, 2015 08:22 AM
ZaqAtaq
Sep 5, 2015 08:57 PM
