New to RX-7's
Old Oct 27, 2009 | 01:51 AM
K-Nives's Avatar
Zoom Zoom Zoom
New to RX-7's
Hey there!
Im on the verge of buying a 1983 RX-7 and am wondering what I should be prepared for. Im more worried about maitenence issues, like how often am I going to need to look this car over and what I should be doing to take care of it.
Thanks for your time guys!
Old Nov 9, 2009 | 02:22 AM
gizza666's Avatar
Im also new to rx7's, and need the help sorry about using this thread, but i can't creat my own one. Im looking at buying a 1984 rx7, and need help as it says the steering box has freeplay in it and was wondering if it was a big problem. Any Help appreciated.
Cheers Matt
Old Nov 9, 2009 | 09:33 AM
Kentetsu's Avatar
Welcome aboard. They're fun cars, and can be dependable if properly cared for.
Spend some time reading over in the 1st gen section.
Old Nov 9, 2009 | 02:56 PM
gizza666's Avatar
Okay thanks
Old Nov 9, 2009 | 11:23 PM
kutukutu1's Avatar
They are not cras that are hard to take care off. The usual run down, chnage the oil regularly and change fuel filter, maintain proper coolant and oil levels and the cra should run like a champ. According to the condition of the car, then you may expect some problems, like the freeplay in the steering box( to answer your question, i just changed mine like a week ago and its not so hard, a couple of bolts, a gear puller, a big hammer, wd40, and patience and persistence will get a new one in there, or you can take it to a shop and get charged like $350 for changing it only. A problem, not really, i spent a year with mine, with more than 2 inches of free play to each side, you get used to it) The other stuff, is to do a carb rebuild according to carb condition, flush fuel tank, flush radiator, change oil, new spark plugs and remove rats nest if your state does not have smog control and last of all, as you go along change all the vaccum lines little by little, you will be greatful later. apart from that, it should not be big problems that would render your car undrivable. If any problem comes up there is tons of help here for any problem. We have seen it all. lol good luck
Old Nov 10, 2009 | 01:05 AM
global247's Avatar
owned a few of them... find someone who is knowledgable about rotary engines and pick their brain. If they will let you watch them work on one take the time to do so
Old Nov 10, 2009 | 06:50 PM
K-Nives's Avatar
Zoom Zoom Zoom
Thanks a bunch for the info guys! I finnaly got to go test drive the thing and fell in love.
Defenetly not used to the whole non power steering thing tho haha!
Old Nov 11, 2009 | 08:44 AM
Kentetsu's Avatar
Air up the tires, and take it somewhere for a lube job. Most quick change oil places will grease the front end for you for free, simply in hopes of generating future business. Or, better yet, buy a grease gun and get your own hands dirty. That helps a lot as far as turning effort goes.
As far as slop in the steering goes, it's an issue with most older 7s. 90% of the slop can be taken care of simply by replacing tie rod ends, idler arm, ball joints, bushings, and maybe one or two other things. Most of these items will need to be replaced anyway, so you might as well do it right off the bat so that you can enjoy the results yourself.
Old Nov 11, 2009 | 11:46 AM
Damzil's Avatar
E-peen
welcome!
I wanna see pics of the car, we love before and after pics of 7s being worked on!!
Old Nov 11, 2009 | 03:07 PM
gizza666's Avatar
I Will be posting oictures and help forums, as im going to being a lot to my rx7 when i get it, i cant wait XD
Old Nov 12, 2009 | 01:20 PM
K-Nives's Avatar
Zoom Zoom Zoom
Getting killed by my budget right now so I wont have it till the end of this month. But as soon as I have it Ill be posting pics!
Old Nov 19, 2009 | 02:21 PM
ragedFD's Avatar
thanks for the info guys. im still interested in buying an FD, but i heard the FC's tend to break often. there beautiful cars though!
Old Nov 19, 2009 | 08:48 PM
rx7nubie's Avatar
DO A COMPRESSION TEST this can give you a good estimate of the condition of the seals/engine also look all around the car like interior condition body, paint, frame, coolant leaks(or leaks of any kind) if these things dont pass your inspection it is always better to wait and find one that dose pass your inspection you willl be glad you waited. read up all the information you can and take a look at a few buying guides for a more specific list on what to look for and how to check the condition. good luck and welcome to the wonderful world of rx7's
Old Nov 23, 2009 | 06:27 PM
ethien161's Avatar
keep a quart of Dino oil in your car check oil levels every time your filling up on gas
alfred1976
RX-7 Audio/Visual Lounge
Dec 3, 2015 03:06 AM
Duc852
Sep 22, 2015 03:49 AM
