Megasquirt gsl-se
Old Oct 24, 2009 | 01:25 PM
jd89's Avatar
gsl-se
ok im new to this fuel injected stuff, a friend turned me to mega squirt, i dont know if i need to list mods but i will to help out, ok header exhaust, msd coils, clutch 12lb flywheel, bonaz intake kit, the deal is that i wont to run 2 rc 750cc injectors and i need a ecu, what mega squirt ecu should i go with, and how should i tune it
Old Oct 24, 2009 | 04:16 PM
jd89's Avatar
anyone?
Old Oct 25, 2009 | 10:31 AM
Aaron Cake's Avatar
Engine, Not Motor
Do you want to run the GSL-SE dizzy, or convert to 2nd gen ignition?
If you are converting to 2nd gen ignition, start here: http://www.aaroncake.net/rx-7/megasquirt
If you are going with the dizzy, then you can trigger the Megasquirt from the leading coil. If you want to build the 'Squirt yourself, pick up a V3 board and MSII chip. If you are buying premade, get a 3.57 board and an MSII chip. Configure either one for triggering from the coil (See the Megamanual).
See http://www.aaroncake.net/rx-7/megasq...asictuning.asp for basic tuning info.
NickNac113
13
Oct 1, 2015 09:25 PM
