Which plugs are leading and which are trailing?
Old Oct 23, 2009 | 12:08 PM
bondospecial's Avatar
I am ready to do the compression test on my 13B but the instructions say to put my modified compression gauge in each trailing plug hole. I see the 4 plugs on the driver's side of my NA 13B. Which two are trailing, the two lower-most plugs?
Thanks
Steve
Old Oct 23, 2009 | 01:42 PM
RotaryRocket88's Avatar
Top Down, Boost Up
The top plugs are trailing & the bottom ones are leading. There will also be the letters 'T' and 'L' cast into the housings.
Old Oct 23, 2009 | 03:55 PM
Is it correct that I use the trailing plug holes for the compression testing? I have a gauge with a removable schrader valve that I will take out so I can check the individual rotor pulses
Thanks
Old Oct 23, 2009 | 06:00 PM
Rotospeed's Avatar
i use the leading.
Old Oct 23, 2009 | 06:02 PM
Top Down, Boost Up
Most guides say to use the trailing holes, but I've done both and had the same results.
Old Oct 23, 2009 | 06:42 PM
w.sen's Avatar
In a Bucket
Ya trailing top... leading bottom.. I have NGK wires trailing is blue and leading is black.. That might help a little bit.. Also I have NGK plugs and there is blue rings around the trailing plugs and there is nothing around the leading plug
Old Oct 23, 2009 | 07:01 PM
misterstyx69's Avatar
Retired Moderator, RIP
www.rotaryresurrection.com hit on your generation of car,then hit:Tech ..and enter the section.then read away..good stuf in there.
Old Oct 23, 2009 | 09:21 PM
Thank you!!
Old Oct 23, 2009 | 10:49 PM
farberio's Avatar
NASA-MW ST4
To provide overkill to this thread.
The simple way to remember is.
(T) - Trailing Top
(L) - Leading Lower
ZacMan
Sep 19, 2015 09:20 PM
Enzo1944
Sep 6, 2015 08:57 AM
