Midwest RX-7 Forum Serving KY, IN, IL, MO, MI, WI, IA, MN, ND, SD, NE, KS
93 RX-7 Rejuvenation in MI
Old Oct 21, 2009 | 11:13 PM
MuttGrunt's Avatar
Enthusiast
MI 93 RX-7 Rejuvenation in MI
Certain cars bring their owners love at first site, while others slowly grow on their owners; creating a long-term bond that many feel is the pinnacle of a good relationship. This particular 1993 Mazda RX-7 has been both for her owner. He's not the original owner: he purchased the vehicle at a young age, and throughout the years has modified it, torn it apart, rebuild things, acquired new parts, added updates, stripped it to a shell, had it repainted, and put it all back together again. The result is a beautifully modded and well kept car that, with a little work, came back to as close to like-new as possible.
Upon the initial inspection/estimate, there were several areas key to the owner: contamination of the paint, light swirls, his aftermarket wheels, and the leather seats. Once we arrived and set-up, the after-market wheels were the first thing to receive attention. This was easier as the owner still had his track slicks mated to the car, leaving us complete access to the pretty ones. Because it was accessible, we wanted to insure the inside got cleaned as well.
Meguiar's Wheel Brightener was used on the inside of the rims to make quick work of the grime. Jacob agitated with a shmitt before rinsing the back-sides clean.
A similar process was used on the fronts, but they were treated with Chemical Guy's Stick Wheel Gel diluted 3:1
In the mean time, I began applying Meguiar's APC 4:1 and Meguiar's Super Degreaser 4:1 to various body parts to pre-treat them prior to washing. Much of the lower portions had rubber and grime built up from the last open-track day.
One other such area to pre-treat was the dirty/stained gas cap.
All clean minus the stains.
Old Oct 21, 2009 | 11:14 PM
MuttGrunt's Avatar
Enthusiast
With the wheels drying, the body began her bath. Chemical Guy's Citrus Wash & Clear with a slight amount of APC added helped to strip loose grime prior to anything touching the paint.
After a gentle wash, it was apparent there was A LOT of contamination. It turns out the owner hasn't had a coat of wax on the paint since the vehicle was repainted its original color two years ago. Jacob started claying while I worked Leatherique into the front seats. Allowing the Leatherique to sit and do its magic while we finished all things exterior worked out quite well.
Post-claying, a quick rewash insured proper inspection of the paint without interference from dry clay lubricants. The owner was also nice enough to pull off the tail lights so they could be properly dealt with.
Having two pros working makes a huge difference. While one begins on one project, another can handle other issues. In this case, Jacob took care of carefully taping all edges while I worked the headlights
before
Old Oct 21, 2009 | 11:15 PM
MuttGrunt's Avatar
Enthusiast
after
taping finished
An area I was looking forward to was the taillights. In the initial inspection I could tell how old, faded, swirled, and used they looked. The head-lights and fog-lights had been more recently replaced, so weren't all too bad. The tails on the other hand needed some work. The severe swirling caused them to look grey and heavily faded with no gloss or clarity.
Some people play the guitar... I polish things out
Rock-on
Even in the shade you can see the difference in clarity and gloss.
MuttGrunt's Avatar
Enthusiast
Here we show the difference between a polished out tail-light in the shade versus a clean but non-polish tail in the shade. Notice gloss, clarity, quality of reflections, and how tight the camera flash is compared to the two. I tried to get several angles to show this isn't a camera trick - it's a true night-and-day difference in parts which does a lot to bring a car back to life.
While I was working to bring the tails back to life, Jacob was busy bringing the paint back to its highest potential
After testing a half-dozen polish+pad+backing plate combinations (yes, the backing plate makes a difference too), the only thing that would get rid of the stubborn Random Isolated Deep Scratches was using the Flex with M105 with a Meguiar's W66 backing plate and blue hydra LC pad. I followed with the Makita with a 3M Grey Foam backing plate, a green LC pad and M205. The results were stunning.
Old Oct 21, 2009 | 11:16 PM
MuttGrunt's Avatar
Enthusiast
With the paint coming back and turning exceptionally liquidy/glossy after paint correction, Jacob moved onto the first layer of protection, Blackfire applied with the PC, while I gently scrubbed the leather with a boar's hair brush and diluted Woolite.
Taking off the hazed Blackfire, Jacob reveals the liquid silver paint
This last foaming was the completely insure removal of polish dust from crevices, and was done with Chemical Guy's Maxi Suds II
Temperatures were dropping fast (mid 40's and dropping), so cold weather gear like gloves needed to be used. What do you Florida / SoCal boys know about this :P
Pressure-washed
Blackfire doing the beading-thing it likes to do
Blown dry
MuttGrunt's Avatar
Enthusiast
Last thing to do: wax. Fuzion got called to action and performed beautifully
By applying the wax after the final wash, we insured maximum amount of time for the wax to "cure" (technically, wax doesn't cure: there's no chemical reaction taking place that needs to finish, rather the solvents completely evaporate from the solids - drying). Winter-prep wasn't an issue as this car is garage kept and babied meaning we actually got to use something other than sealants unlike most of the work we've been doing lately. Thanks owner!!! (the things that makes detailers happy... )
Meguiar's Trim Detailer used on the diffuser, cowl, etc and the car was tucking in for the night.
The next day, Jacob and I went out and met the client to get some day-time afters, give the car a last wipe down, and insure no issues.
**** towel + M34 was used as dust removal, a quality shorter nap microfiber + Dodo Juice Red Mist Tropical were used for added shine/protection
Seats before:
Seats now:
Old Oct 21, 2009 | 11:17 PM
MuttGrunt's Avatar
Enthusiast
Final shots and a swirl-free finish...
Thanks for watching!!!
oh... and yes, we'll hopefully get pics with the other wheels on the car soon enough, and if we do, we might post them up here
Old Oct 21, 2009 | 11:18 PM
MuttGrunt's Avatar
Enthusiast
Old Oct 23, 2009 | 12:04 AM
Spazm_81's Avatar
Spirit 7
Beautiful 7! I need to get my 93 running again...
Old Oct 23, 2009 | 02:58 AM
Ratjar's Avatar
..sweet! come do my my car. thats beautiful
Old Oct 23, 2009 | 04:05 AM
wackaloo13's Avatar
wow.... that is amazing
Old Oct 30, 2009 | 06:34 AM
MuttGrunt's Avatar
Enthusiast
Thanks for the comments guys
Old Nov 8, 2009 | 10:20 AM
MeLoN350's Avatar
A few I took after putting the wheels back on. I would highly recommend these guys if anyone in the area is looking for a great detail job.
Old Nov 9, 2009 | 10:09 PM
MuttGrunt's Avatar
Enthusiast
Thanks bro! She's still looking like liquid silver and hope all is well for you
alfred1976
RX-7 Audio/Visual Lounge
Dec 3, 2015 03:06 AM
Duc852
Sep 22, 2015 03:49 AM
