Megasquirt NEED HELP BAD!!! I need an MSQ file for 13BTII using 550 injec and 2.1.0 firm ware!!
Old Oct 20, 2009 | 07:39 PM
immanuel__7's Avatar
NEED HELP BAD!!! I need an MSQ file for 13BTII using 550 injec and 2.1.0 firm ware as i can get my car running but it runs like **** like its misfiring or something used to run fine with 1.01 firm ware tho... i have some client to attend to in the morning and the rest of the week I need my rx7 back lol. DJ55b was supported to help me out but his cell is messed up so now im up **** creak and my paddle is not configured for ms2 2.1.0 lol
any ways i need a running msq file for the 13B S5 turbo na i dont care as i can tune the aft and ing after but would be nice to have a turbo MSQ (im using stock turbo 10psi)
thanks for your help
Old Oct 20, 2009 | 08:50 PM
ok DJ55b fixed his cell prob and called up just as i got the car running ish.. now to pull 50% of the fuel off as both injectors are now firing.
if some one still has an msq to post that would be cool and help full still. if non is added i think il add mine once im done for the next poor sucker lol
Old Oct 21, 2009 | 01:53 PM
toplessFC3Sman's Avatar
Attached is mine. Its got 1000cc secondary injectors, not 550s, but if you just change the scaling factor, then you'll be fine. The timing is also set up for the CAS stabbed at the 1,3,7,9 position from MS1, boost control and closed loop idle are being used, and its set up for an Innovate LC-1 wideband, but all the maps and whatnot there should be good enough to get you going.
Old Oct 21, 2009 | 08:41 PM
cool thanks!!
Old Oct 22, 2009 | 10:49 PM
i still did not have time to try your msq but will get on that in the morning i think if i have time lol
RedBaronII
Sep 20, 2015 11:29 AM
